- To:
- Subject: Re: Re: [cgal-discuss] Access vertices of faces in Delaunay
- Date: Sun, 15 Feb 2009 18:34:27 +0100 (CET)
I don't get it. I think my problem is to declare the correct data structure?
// additional .h files
#include <CGAL/Triangulation_vertex_base_2.h>
#include <CGAL/Triangulation_vertex_base_with_info_2.h>
#include <CGAL/Triangulation_data_structure_2.h>
struct K : public CGAL::Exact_predicates_inexact_constructions_kernel {};
// Traits
typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
// Data structure with info
typedef int Index;
typedef CGAL::Triangulation_vertex_base_with_info_2<Index, K> Info;
typedef CGAL::Triangulation_data_structure_2<Info> Tds;
// Triangulation constructor
typedef CGAL::Delaunay_triangulation_2<Gt,Tds> CDT;
typedef K::Point_3 Point;
typedef CDT::Finite_faces_iterator Finite_faces_iterator;
How do i assign indices to the vertices? Section 29.11 does not really help
me.
I'm new to CGAL.
- [cgal-discuss] Access vertices of faces in Delaunay Triangulation, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay Triangulation, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Manuel Caroli, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/16/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/17/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/17/2009
