- To:
- Subject: Re: Re: [cgal-discuss] Access vertices of faces in Delaunay
- Date: Sun, 15 Feb 2009 19:13:56 +0100 (CET)
Hi Andreas,
I understand what the info does but i can't compile when including the info
class?
I get this error
‘class
CGAL::Tdsfb<CGAL::Tds2<CGAL::Triangulation_vertex_base_with_info_2<int, K,
CGAL::Tvb<K, CGAL::Tdsvb<void> > >, CGAL::Tdsfb<void> > >’ has no member
named ‘info’
The problem must be here:
typedef CGAL::Triangulation_euclidean_traits_xy_3<K> Gt;
typedef CGAL::Triangulation_vertex_base_with_info_2<Index, K> Info;
typedef CGAL::Triangulation_data_structure_2<Info> Tds;
typedef CGAL::Delaunay_triangulation_2<Gt,Tds> CDT;
Is it possible to use 2D Delaunay Triagulation with the info class?
- [cgal-discuss] Access vertices of faces in Delaunay Triangulation, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay Triangulation, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Manuel Caroli, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/16/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/17/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/17/2009
