- To:
- Subject: Re: [cgal-discuss] Access vertices of faces in Delaunay
- Date: Mon, 16 Feb 2009 17:26:18 +0100
Hi Matthias,
the method
insert ( InputIterator first, InputIterator last)
does not guarantee to insert the points in the order of the InputIterator.
I don't understand how you assign the indices to your vertices but might it be related to the possible scrambling of the insertion order?
best
Manuel
wrote:
Many thanks! It works.
However i found an interesting problem. If i insert the points one after each
after to the triangulation it works fine but when i insert an list with all
points to the triangulation in one go i sometimes end up with an wrong result?
Delaunay.insert(Point(x,y,z)); //works
Result of vertex indices of each face:
1 3 2
1 5 3
3 5 4
1 0 5
coord.push_back(Point(x,y,z));
Delaunay.insert(coord.begin(),coord.end()); // doenst work always correct
Result(s!) of vertex indices of each face:
1 3 2
1 5 3
3 5 4
1 0 5
or
3 1 2
1 5 2
2 5 4
1 0 5
Any suggestions? Maybe the list is read in wrong.
- [cgal-discuss] Access vertices of faces in Delaunay Triangulation, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay Triangulation, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Manuel Caroli, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/16/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/17/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/17/2009
