- To:
- Subject: Re: [cgal-discuss] Access vertices of faces in Delaunay
- Date: Tue, 17 Feb 2009 13:33:06 +0100
Hello Matthias,
This has nothing to do with CGAL
std::cout.precision(20) should do the job.
It's the same for an ofstream.
andreas
wrote:
THANK YOU VERY MUCH!
I begin to understand the concept now and i'm impressed. Only one point is
left. I read in my 3d points with:
ifstream in(surface.dat);
istream_iterator<Point> begin(in);
istream_iterator<Point> end;
Delaunay2.insert(begin, end);
I do the triangulation and assign indices to the vertices. After that i want
to
store the 3d points in a new file so that i can work with the new order. When
i
try to get out the coordinates from the vertices i have a problem.
fvii->info()= index++;
Point p = fvii->point();
cout << p.hx() << " " << p.hy() << " " << p.hz()<< endl;
//with
//struct K : public CGAL::Exact_predicates_inexact_constructions_kernel {};
//typedef K::Point_3 Point;
The input file has the format:
123456.789 1234567.890 123.456
However if i write the coordinates to an output file i get the following
format:
123456 1.23456e+06 123.45
Does the Kernel uses double? I also tried p.cartesian() and p.homogeneous()
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, (continued)
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Manuel Caroli, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/16/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/17/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/17/2009
