- To:
- Subject: Re: [cgal-discuss] Access vertices of faces in Delaunay
- Date: Mon, 16 Feb 2009 17:55:52 +0100
wrote:
Hmm. When the insertion has no order how can i ensure i keep my input order ofYou can use the second possibility Andreas gave you yesterday:
my points?
Vertex_handle vh = dt.insert(points[i]);
vh->info() = i;
But it might run a bit slower. In fact there is an optimization hidden in the method insert(InputIterator, InputIterator) that scrambles the order.
If i want read out the vertices or faces of the finished triangulation is thisI'm not sure what you mean. But the same output iterator should always give the same order if you don't change the triangulation in between. However it need not be the insertion order.
in a non-changing order?
Because if the input is random and the output how can i ensure reliability?I am not sure whether I understand your question. Don't you attach the indices to vertices? So how does the order matter?
see above.
coord.push_back(Point(x,y,z));
//How do i assign an index to the point which is put in the "coord" list?
at the moment i do that after the triangulation because i thought it was in
order.
// Loop through faces of triangulation and assign index to vertices
int q = 0;
for (Finite_vertices_iterator fvi = Delaunay.finite_vertices_begin();
fvi !=
Delaunay.finite_vertices_end();++fvi){
fvi->info()= q++;
- [cgal-discuss] Access vertices of faces in Delaunay Triangulation, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay Triangulation, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/15/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/15/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Manuel Caroli, 02/16/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/16/2009
- Re: Re: [cgal-discuss] Access vertices of faces in Delaunay, matthias.kunz, 02/17/2009
- Re: [cgal-discuss] Access vertices of faces in Delaunay, Andreas Fabri, 02/17/2009
