- To:
- Subject: Re: [cgal-discuss] Jet_fitting_3
- Date: Thu, 05 Mar 2009 08:36:28 +0100
Hello,
It might be that there is a bug in the cmake rule for finding this lib.
I yesrarday had the same problem with the Surface_mesh_paramtrization
examples.
We will investigate and let you know on the discussion list.
best regards,
andreas
naresh wrote:
Hi
I think you have not installed boost library properly. Please check where installed boost libray should be lib directory . If you installed from installer and using windows then it should be
C:\Program Files\boost\boost_1_37\lib
Check for libboost_program_options-vc90-mt-gd-1_37.lib if it doesnot exist on directory try to run setup of boost otherwise please set file correct path from project settings.
hope this will helps
regards
naresh
----- Original Message -----
<mailto:>
*To:*
<mailto:>
*Sent:* Thursday, March 05, 2009 11:33 AM
*Subject:* [cgal-discuss] Jet_fitting_3
Hi
I am trying to get the jet_fitting example code to compile on my
machine and I keep getting the following error:
LINK : fatal error LNK1104: cannot open file
'libboost_program_options-vc90-mt-gd-1_37.lib
I have Boost installed on my machine and it is linked with CGAL
projects.
Has anyone else seen this?
Sincerely
Priyamvad
- [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, naresh, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, Andreas Fabri, 03/05/2009
- [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/06/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/07/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Mahmood Naderan, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/09/2009
