- To:
- Subject: Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?
- Date: Thu, 05 Mar 2009 19:12:11 -0200
Hi Tom,
Hi Fernando,
thanks for your answer. Why do you think I used the old installer
system?
Because of this:
>>> $(CGALROOT)\include
>>> $(CGALROOT)\auxiliary\gmp\include
>>> $(BOOSTROOT)
>>> And my Linker-Dirs are:
>>> $(CGALROOT)\lib
>>> $(CGALROOT)\auxiliary\gmp\lib
>>> $(BOOSTROOT)\lib
That doesn't look quite like the set of directories that a project file generated via CMake would contain.
In fact, it looks exactly like the setup used in CGAL 3.3.1
Could those be in your gobal IDE settings rather than the cmake generated solution?
In windows, the gmp libs (which are producing your linker errors) are auto-linked, but the libs directory must be correct.
So what could it be else?
Can you post the output from cmake just to be sure there is nothing odd going on?
HTH
Fernando Cacciola
www.geometryfactory.com
- [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, naresh, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, Andreas Fabri, 03/05/2009
- [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/06/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/07/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Mahmood Naderan, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/09/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/10/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/10/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
