cgal-discuss - Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?
  • To:
  • Subject: Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?
  • Date: Sun, 8 Mar 2009 10:45:28 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=DPFeJ16TIKvTBmN6Ei5gs35WN0MozhA7Z0UtElnDciMW1ARrO8O5Vi/Eg21J4bslgcQkrUXXx8Iyo1OvTz0+FRRb+H5GME4zbh4lKTJhiZr12QyJYPc2+7F4ht8FhvkhWIyknWNdsDJadgK479XaVoj0rlCRNCSY6W72GJegmBI=;
Hi,
>Can you do me a favor and post your linker and compiler directories (includes and libs) for the named example (added_handles). I guess >they are the same as mine (except for the path), since they are generated.
These values are pure defaults.I didn't change any thing. Yours might be the same. Do you have boost libboost_thread and boost_program_options?
C/C++:
Additional include directories:
C:\Program Files\CGAL-3.4\examples\Triangulation_2
C:\Program Files\CGAL-3.4\auxiliary\gmp\include
C:\Program Files\CGAL-3.4\include
C:\Program Files\boost_1_36_0
Preprocessor definitions:
WIN32
_WINDOWS
_CRT_SECURE_NO_DEPRECATE
_SCL_SECURE_NO_DEPRECATE
_CRT_SECURE_NO_WARNINGS
_SCL_SECURE_NO_WARNINGS
_DEBUG
CMAKE_INTDIR=\"Debug\"
Linker:
Additional library direcoties:
C:\Program Files\CGAL-3.4\lib\$(OutDir)
C:\Program Files\CGAL-3.4\auxiliary\gmp\lib\$(OutDir)
C:\Program Files\boost_1_36_0\lib\$(OutDir)
Input->additional dependecies:
kernel32.lib
user32.lib
gdi32.lib
winspool.lib
shell32.lib
ole32.lib
oleaut32.lib
uuid.lib
comdlg32.lib
advapi32.lib
psapi.lib
Mahmood Naderan
To:
Sent: Sunday, March 8, 2009 11:24:45 AM
Mahmood,
thanks for your test. Actually, I tryed it with both cmake and cmake-gui - both with the same results. The precompiled libs for GMP I use are the ones deployed with the installer (in the aux. folder). I can build the solution (sln) if I do not install the examples. If I install them they are part of the solution, too, but, like I said, producing the gmp-methods linking errors (at least some).
That it works for you lets me hope that the problem is located somewhere here with my system - I guess 64bit are no problem?
Can you do me a favor and post your linker and compiler directories (includes and libs) for the named example (added_handles). I guess they are the same as mine (except for the path), since they are generated.
Thanks,
Tom
-------- Original-Nachricht --------
> Datum: Sat, 7 Mar 2009 22:32:19 -0800 (PST)
> Von: Mahmood Naderan <>
> An:
> Betreff: Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?
> Hi,
> >now I deinstalled CGAL 3.3.1 completely and reinstalled CGAL 3.4 again,
> >checked the environment variables, hardcoded absolute directory,
> >recompiled and even in the generated example files I get these errors.
> I compiled the example without any problem. You have to use
> "cmake-gui.exe"
> instead of "cmake.exe". Do you have the right precompiled libs for gmp
> (debug version)?
> can you build CGAL.sln after you configure it for VS?
> Mahmood Naderan
> ________________________________
> From: Tom Kazimiers <>
> To:
> Sent: Saturday, March 7, 2009 4:18:41 PM
> Hi,
> Do you have any suggestions where to look else?
> Regards,
> Tom
> Tom Kazimiers schrieb:
> > Fernando,
> > thanks for your reply. I checked everyting by putting in the CGAL
> > 3..4-Paths fully, without environment variables - the same result.
> > Like I said points the CGALROOT environment variable to the CGAL 3.4
> > root directory.
> > The output of cmake is the following:
> > P:\Program Files (x86)\CGAL-3.4>cmake .
> > -- CGAL_MAJOR_VERSION=3
> > -- CGAL_MINOR_VERSION=4
> > -- CGAL_BUILD_VERSION=
> > -- CGAL_SONAME_VERSION=3
> > -- CGAL_SOVERSION    =3.0.0
> > -- CGAL_REFERENCE_CACHE_DIR=
> > -- Building static libraries
> > CMake Warning (dev) at CMakeLists.txt:88 (include):
> >  Policy CMP0011 is not set: Included scripts do automatic cmake_policy
> PUSH
> >  and POP.  Run "cmake --help-policy CMP0011" for policy details.  Use
> the
> >  cmake_policy command to set the policy and suppress this warning.
> >  The included script
> >    P:/Program Files (x86)/CGAL-3.4/cmake/modules/CGAL_Common.cmake
> >  affects policy settings.  CMake is implying the NO_POLICY_SCOPE
> option for
> >  compatibility, so the effects are applied to the including context.
> > This warning is for project developers.  Use -Wno-dev to suppress it.
> > -- Targetting Visual Studio 9 2008
> > -- Target build enviroment supports auto-linking
> > -- Using VC90 compiler.
> > -- Generator uses intermediate configuration directory: $(OutDir)
> > -- USING CMake version: 2.6.3
> > -- System: Windows
> > -- Build type: Release
> > -- USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR
> > -D_CRT_SECURE_NO_DEPRECA
> > _SCL_SECURE_NO_WARNINGS /MD /O2 /Ob2 /D NDEBUG -D_SECURE_SCL=0'
> > -- USING LDFLAGS = ' '
> > -- GMP include:    P:/Program Files
> (x86)/CGAL-3.4/auxiliary/gmp/include
> > -- GMP libraries:
> > -- GMP definitions:
> > -- USING GMP_VERSION = '4.2.4'
> > -- MPFR include:      P:/Program Files
> > -- MPFR libraries:
> > -- MPFR definitions:
> > -- USING MPFR_VERSION = '2.3.2'
> > -- Boost include:    D:/Install/Libraries/BOOST/boost_1_37_0
> > -- Boost libraries:
> > optimized;D:/Install/Libraries/BOOST/boost_1_37_0/lib/libboost_th
> > st_1_37_0/lib/libboost_thread-vc90-mt-gd-1_37.lib
> > -- Boost definitions:
> > -- USING BOOST_VERSION = '1.37.0'
> > -- CMAKE_INSTALL_PREFIX=P:/Program Files (x86)/CGAL
> > -- Configuring done
> > -- Generating done
> > -- Build files have been written to: P:/Program Files (x86)/CGAL-3.4
> > Seems there something odd? I have previously disabled Qt3 and Qt4.
> > Regards,
> > Tom
> > Fernando Cacciola schrieb:
> >> Hi Tom,
> >>> Hi Fernando,
> >>> thanks for your answer. Why do you think I used the old installer
> >>> system?
> >> Because of this:
> >>>>> $(CGALROOT)\include
> >>>>> $(CGALROOT)\auxiliary\gmp\include
> >>>>> $(BOOSTROOT)
> >>>>> And my Linker-Dirs are:
> >>>>> $(CGALROOT)\lib
> >>>>> $(CGALROOT)\auxiliary\gmp\lib
> >>>>> $(BOOSTROOT)\lib
> >> That doesn't look quite like the set of directories that a project
> >> file generated via CMake would contain.
> >> In fact, it looks exactly like the setup used in CGAL 3.3.1
> >> Could those be in your gobal IDE settings rather than the cmake
> >> generated solution?
> >> In windows, the gmp libs (which are producing your linker errors) are
> >> auto-linked, but the libs directory must be correct.
> >>> So what could it be else?
> >> Can you post the output from cmake just to be sure there is nothing
> >> odd going on?
> >> HTH
> >> Fernando Cacciola
> >> www.geometryfactory.com
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Computer Bild Tarifsieger! GMX FreeDSL - Telefonanschluss + DSL
für nur 17,95 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
