cgal-discuss - Re: [cgal-discuss] Jet_fitting_3
  • To:
  • Subject: Re: [cgal-discuss] Jet_fitting_3
  • Date: Thu, 5 Mar 2009 23:43:09 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=TYPONdo/gV0KTssJ5MCvZQuzD25WOgX5u1BqSfzH6vcyxQpj5mKYMHerudcpjMd8I0 k9AHH1q5GBBP0Ji6oFrZfJu9BAYFsmF73FdJDvyOsNLJntnJqiyddH2saRoakZ9Bw5gp hwRXO790JuqhsRFiWXLxhjBNeC2RtKqT9TCEU=
Hi
I got the fitting process running and used it to estimate the umbilics and ridges on a triangular mesh.
I have attached the images for the results I get for a torus with this mail. Can someone who has had an experience with using jet_fitting and umbilics/ridge estimation before, let me know if these look correct?
I have used a 2-ring neighbourhood for estimating the umbilics and a third order approximation for the ridges.
Also. does anyone know if the min and max elliptic edges will always connect the umbilics?
Sincerely
Priyamvad
Color Code:
Blue Sphere: Umbilic
Red Line: Max elliptic ridge
Yellow Line: Min elliptic ridge
On Thu, Mar 5, 2009 at 8:43 AM, Priyamvad Deshmukh <> wrote:
Thanks everyone. I was sleeping in the other part of the world, hence the delay.
I had boost libraries for the incorrect VC version. Reinstalling solved the problem. Jet_fitting runs nicely now.
I will try and incorporate Monge_fitting for my mesh implementation today. My goal is to get all the umbilics on a mesh.
Thanks again
Priyamvad
On Thu, Mar 5, 2009 at 3:53 AM, Laurent Rineau (GeometryFactory) <> wrote:
On Thursday 05 March 2009 08:36:28 Andreas Fabri wrote:
> Hello,
> It might be that there is a bug in the cmake rule for finding this lib.
> I yesrarday had the same problem with the Surface_mesh_paramtrization
> examples.
> We will investigate and let you know on the discussion list.
Priyamvad has a *link* error. That is a different problem. Maybe the library
does not exist on the machine, or the library path is wrong.
Priyamvad, please answer the usual questions, so that we can help you:
 http://www.cgal.org/bug_report.html
At the very least, what is your compiler? It seems to be VC90, can you
confirm? What version of CGAL? Is your OS for x86 or x64?
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
Priyamvad
http://www.columbia.edu/~prd2112/
MS in CS
Columbia University
Priyamvad
MS in CS
Columbia University
Attachment: umbilics.jpg
Description: JPEG image
Attachment: torus.jpg
