- To:
- Subject: Re: [cgal-discuss] Jet_fitting_3
- Date: Thu, 5 Mar 2009 09:53:39 +0100
On Thursday 05 March 2009 08:36:28 Andreas Fabri wrote:
> Hello,
> It might be that there is a bug in the cmake rule for finding this lib.
> I yesrarday had the same problem with the Surface_mesh_paramtrization
> examples.
> We will investigate and let you know on the discussion list.
Priyamvad has a *link* error. That is a different problem. Maybe the library
does not exist on the machine, or the library path is wrong.
Priyamvad, please answer the usual questions, so that we can help you:
http://www.cgal.org/bug_report.html
At the very least, what is your compiler? It seems to be VC90, can you
confirm? What version of CGAL? Is your OS for x86 or x64?
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, (continued)
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/06/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/07/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Mahmood Naderan, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/09/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/10/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/10/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, Laurent Rineau (GeometryFactory), 03/05/2009
- Re : [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/06/2009
- Re: [cgal-discuss] Jet_fitting_3, Marc Pouget, 03/08/2009
