Re: [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points
- To:
- Subject: Re: [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points
- Date: Thu, 5 Mar 2009 14:59:23 +0100
On Thursday 05 March 2009 14:54:25 BBB HHH wrote:
> Hello every one,
> I want to triangulate a Polygon_without_holes_2. Moreover, i want to do it
> without introducing Steiner (new) points.
> Is there a mean to do that within CGAL ?
First remark: that has nothing to do with Jet_fitting_3, which was the first
subject of the thread. You should have started a new thread, instead of
replying to a message.
If you want to triangulate a 2D polygon, without Steiner points, you can use
the convex decomposition package of CGAL, and then simply triangulate your
convex parts as you want (choose a vertex, and then star the convex part from
that vertex).
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, (continued)
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/06/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/07/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Mahmood Naderan, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/08/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, Laurent Rineau (GeometryFactory), 03/05/2009
- Re : [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/06/2009
- Re: [cgal-discuss] Jet_fitting_3, Marc Pouget, 03/08/2009
