- To:
- Subject: Re: [cgal-discuss] Jet_fitting_3
- Date: Thu, 5 Mar 2009 08:43:41 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=JIzqY6cbLjEOdd63eNw9dTjywRS1EaAbA70+mQVhvh97R0QIAp1wO5wJJg3HOWX5FO hGqIzXku15aJIuLs+DRFGAN8GXtbXHRHbblK0qP3a0ObMTjUzjWz8HgIB3Egq/1OQo6S /7+K+gmis8wCatMBKkrph9rZj+kIpY7Ongdkc=
Thanks everyone. I was sleeping in the other part of the world, hence the delay.
I had boost libraries for the incorrect VC version. Reinstalling solved the problem. Jet_fitting runs nicely now.
I will try and incorporate Monge_fitting for my mesh implementation today. My goal is to get all the umbilics on a mesh.
Thanks again
Priyamvad
On Thu, Mar 5, 2009 at 3:53 AM, Laurent Rineau (GeometryFactory) <> wrote:
On Thursday 05 March 2009 08:36:28 Andreas Fabri wrote:Priyamvad has a *link* error. That is a different problem. Maybe the library
> Hello,
> It might be that there is a bug in the cmake rule for finding this lib.
> I yesrarday had the same problem with the Surface_mesh_paramtrization
> examples.
> We will investigate and let you know on the discussion list.
does not exist on the machine, or the library path is wrong.
Priyamvad, please answer the usual questions, so that we can help you:
http://www.cgal.org/bug_report.html
At the very least, what is your compiler? It seems to be VC90, can you
confirm? What version of CGAL? Is your OS for x86 or x64?
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
Priyamvad
http://www.columbia.edu/~prd2112/
MS in CS
Columbia University
- Re: [cgal-discuss] Jet_fitting_3, (continued)
- Re: [cgal-discuss] Jet_fitting_3, Andreas Fabri, 03/05/2009
- [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/06/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/07/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Mahmood Naderan, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/08/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, Laurent Rineau (GeometryFactory), 03/05/2009
- Re : [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/06/2009
- Re: [cgal-discuss] Jet_fitting_3, Marc Pouget, 03/08/2009
