- To: <>
- Subject: Re: [cgal-discuss] Delaunay triangulation Question
- Date: Mon, 30 Mar 2009 18:07:21 +0530
Hi
But how can save my points in to .inr file ?
----- Original Message ----- From: "Mariette Yvinec" <>
To:
Sent: Monday, March 30, 2009 5:49 PM
Monique Teillaud wrote:
Hi,
For example, I have a coordinate list like x, y, z about 1000 points. This points belong to a real 3D surface. I would like to construct a triangular mesh using 3D delaunay triangulation function. So, I can construct a 3D surface model.
Then maybe what you need is not a 3D Delaunay triangulation but a mesh of your surface.
You may want to have a look at the 3D Surface Mesh Generation package.
Most probably what is needed here is a reconstruction rather than a meshing
and the reconstruction package is not yet available.
> Basically i know how to use Delaunay Tringulation but I still not
understand what it doings ?
As its name says, it is computing a 3D Delaunay triangulation. ie in a nutshell a graph on 3D tetrahedra whose circumscribing balls are empty.
And the API of the class tells you what you can do with it.
Is there any method to convert Delaunay Tringulation to 3D polyhydrone ?
no, just because a 3D triangulation is not a polyhedron...
best
Monique Teillaud
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
- Re: [cgal-discuss] incident_facets function of a Delaunay triangulation, (continued)
- Re: [cgal-discuss] incident_facets function of a Delaunay triangulation, naresh, 03/23/2009
- Re: [cgal-discuss] incident_facets function of a Delaunay triangulation, Query Cgal, 03/23/2009
- Re: [cgal-discuss] incident_facets function of a Delaunay triangulation, Andreas Fabri, 03/23/2009
- [cgal-discuss] Delaunay triangulation Question, naresh, 03/28/2009
- Re: [cgal-discuss] Delaunay triangulation Question, Monique Teillaud, 03/30/2009
- Re: [cgal-discuss] Delaunay triangulation Question, naresh, 03/30/2009
- Re: [cgal-discuss] Delaunay triangulation Question, Mariette Yvinec, 03/30/2009
- Re: [cgal-discuss] Delaunay triangulation Question, Laurent Rineau (GeometryFactory), 03/30/2009
- Re: [cgal-discuss] incident_facets function of a Delaunay triangulation, Andreas Fabri, 03/24/2009
- Re: [cgal-discuss] incident_facets function of a Delaunay triangulation, Manuel Caroli, 03/24/2009
