cgal-discuss - Re: [cgal-discuss] Delaunay triangulation Question
  • To: <>
  • Subject: Re: [cgal-discuss] Delaunay triangulation Question
  • Date: Mon, 30 Mar 2009 19:09:43 +0530
Hi Laurent
Thank for your reply. I also checked with debug code it very tough indeed to implement it.
So do you have any other experimental  source  or may be possible to implement reconstruction like surface mesher which takes input as points. ?
I wish to implement it but i really donot know how i will do this . If  someone helps as some inital code or some example i can implement it.
----- Original Message -----
To:
Sent: Monday, March 30, 2009 6:27 PM
On Monday 30 March 2009 14:37:21 naresh wrote:
> Hi
> But how can save my points in to .inr file ?
No. That is almost the same non-sense as wanting to store vegetables in a flash memory card: a .inr (Inrimage) file is a 3D image. All what it can store is a 3D homogenous array of values (integers, floats), that encodes a 3D image (like JPEG files encode 2D images). You cannot save points in such a file.
Mariette Yvinec gave you the right hint: you need a reconstruction algorithm (that constructs a surface from a pointset). In CGAL-3.4, you can have a look at the 3D alpha shapes:
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/packages.html#Pkg:AlphaShapes3
But there exist better reconstruction algorithms, that are not yet in CGAL (there are new algorithms implementations targetting CGAL-3.5).
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
