- To: CGAL Discuss <>
- Subject: [cgal-discuss] Using finger search with Delaunay Triangulation Hierarchy
- Date: Fri, 17 Apr 2009 16:33:58 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type:content-transfer-encoding; b=ZTmCTr5A5RRQmJR/5vSCSoZx/5fzHAXxDG2l0CIVmuyygxpt0Lw6r6Z4WNhOLXeeWy PRh33XIAnN0ugxxgkGwdHbAGh5eepgcD2srjdN8oGIIiUN3AsTP9sh8G25bj9CRIn9RV 8l+wH2E3jF++U0EpQhMEvtVloOk9dynN4+ZLM=
Hi,
I am trying to perform finger search with the delaunay hierarchy code
from CGAL. That is, I have a random point set which is added as the
points of a delaunay hierarchy / triangulation. Then, I have a list of
query points which lie along a line through this point set. I want to
query for the nearest neighbours of the points on the line.
This sequence of queries should offer good locality, i.e. if I know
the nearest neighbour x of point i on the line, the nearest neighbour
y of point i+1 should be very close to x. Thus, I am trying to use the
second parameter to Delaunay_triangulation_2::nearest_vertex(const
Point& p, Face_handle f= Face_handle()) const.
Will the following code do this, i.e. when calling x->face() (where x
is the nearest neighbour of the i-th query point i), will this return
a face adjacent to x and this helps to speed up the queries?
Thanks,
Manuel
// typedefs/aliases
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
typedef CGAL::Triangulation_vertex_base_2<K> Vbb;
typedef CGAL::Triangulation_hierarchy_vertex_base_2<Vbb> Vb;
typedef CGAL::Triangulation_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<K, Tds> Dt;
typedef CGAL::Triangulation_hierarchy_2<Dt>
Triangulation_hierarchy;
typedef Triangulation_hierarchy::Vertex_circulator
Vertex_circulator_hierarchy;
typedef Triangulation_hierarchy::Point Point_hierarchy;
typedef Triangulation_hierarchy::Vertex Vertex_hierarchy;
typedef Triangulation_hierarchy::Vertex_handle
Vertex_hierarchy_handle;
typedef Triangulation_hierarchy::Face_handle
Face_hierarchy_handle;
void foo(const std::vector<Point_hierarchy> &points, const
std::vector<Point_hierarchy> &queries) {
Triangulation_hierarchy dh;
dh.insert(points.begin(), points.end());
Vertex_hierarchy_handle v = dh.nearest_vertex(queries[0]);
Face_hierarchy_handle f = v->face();
for (int j = 1, jend = queries.size(); j < jend; ++j) {
v = dh.nearest_vertex(queries[j], f);
f = v->face();
- [cgal-discuss] Using finger search with Delaunay Triangulation Hierarchy, Manuel Holtgrewe, 04/17/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/17/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/18/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Sylvain Pion, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/20/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Caroli, 04/22/2009
