- To:
- Subject: Re: [cgal-discuss] Using finger search with Delaunay Triangulation
- Date: Sun, 19 Apr 2009 21:05:32 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=CCVU/bM7w0A8sXCubKmD+dRsU4NzU5/n913UlPJCuuA38livqJfgfpjFUon3PPLjNv Xs5pyExbbiw236HYV2uBxpWvF0yldF/y0lIqnhr2CT88Rj5TeXg+FP4xhi+VRoAqKBoE kGAPYNCP1opu3XaYfB9G1RSHUCRoTMyoYMBVY=
Sylvain,
Thank you for enlightening me! :)
Manuel,
Your non-hierarchical triangulation (dt_build in your notation) calls the dt.insert(begin, end) interface. This interface performs preprocessing to sort the points along a Hilbert curve which improves the performance of insertion. I did not factor this in when I compared computation times for the Delaunay and the Delaunay+hierarchy construction. To perform an apple-to-apple comparison of the performance of these two algorithms you should use the dt/dh.insert(Point) interface.
So in summary, the hierarchy is not being leveraged during construction because the sort ensures the resulting sequence of points is in close geometric proximity; the hierarchy is not being leveraged during nearest_vertex queries because you are already providing a good starting hint. Conclusion, the hierarchy is not doing anything for you so you don't need it.
Best regards,
Damian
On Sun, Apr 19, 2009 at 8:10 AM, Sylvain Pion <> wrote:
Hi Damian,
Damian Sheehy a écrit :This is not true anymore in recent CGAL releases, more precisely
For a random set of points the Delaunay hierarchy should build a triangulation in much less time than the conventional Delaunay without a hierarchy. The numbers do not reflect that, so something is wrong. I will run your example tomorrow and see what I get. . .
since the introduction of a spatial sorting preprocessing phase (BRIO).
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] Using finger search with Delaunay Triangulation Hierarchy, Manuel Holtgrewe, 04/17/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/17/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/18/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Sylvain Pion, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/20/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Caroli, 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Laurent Rineau (GeometryFactory), 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Sylvain Pion, 04/22/2009
