cgal-discuss - Re: [cgal-discuss] Using finger search with Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Using finger search with Delaunay Triangulation
  • Date: Fri, 17 Apr 2009 13:28:33 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=dAs3HbmL3cDbpzeYwSNc3ayuLJljS1GdjZ4ENOM3epbBN7GjB8r8vsdcIa8WoD+7tM tzC5iow3rDTc//Vw74uhXPKGHwwFeW+6WxtWCuyKMZRnlXqXUI2rfkMyBLkoQsB6TKea BT/+hXM+m6xM4UBEtPPGAL7QEL5Oe3Ci9ohMQ=
Hi Manuel,
Based on visual inspection, your code looks correct. You do not have
to special case the first nearest_vertex search; just pass a default
Face_handle in the first iteration of the loop and start the loop from
zero.
Regards,
Damian
On 4/17/09, Manuel Holtgrewe
wrote:
> Hi,
> I am trying to perform finger search with the delaunay hierarchy code
> from CGAL. That is, I have a random point set which is added as the
> points of a delaunay hierarchy / triangulation. Then, I have a list of
> query points which lie along a line through this point set. I want to
> query for the nearest neighbours of the points on the line.
> This sequence of queries should offer good locality, i.e. if I know
> the nearest neighbour x of point i on the line, the nearest neighbour
> y of point i+1 should be very close to x. Thus, I am trying to use the
> second parameter to Delaunay_triangulation_2::nearest_vertex(const
> Point& p, Face_handle f= Face_handle()) const.
> Will the following code do this, i.e. when calling x->face() (where x
> is the nearest neighbour of the i-th query point i), will this return
> a face adjacent to x and this helps to speed up the queries?
> Thanks,
> Manuel
> // typedefs/aliases
> struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
> typedef CGAL::Triangulation_vertex_base_2<K> Vbb;
> typedef CGAL::Triangulation_hierarchy_vertex_base_2<Vbb> Vb;
> typedef CGAL::Triangulation_face_base_2<K> Fb;
> typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
> typedef CGAL::Delaunay_triangulation_2<K, Tds> Dt;
> typedef CGAL::Triangulation_hierarchy_2<Dt>
> Triangulation_hierarchy;
> typedef Triangulation_hierarchy::Vertex_circulator
> Vertex_circulator_hierarchy;
> typedef Triangulation_hierarchy::Point Point_hierarchy;
> typedef Triangulation_hierarchy::Vertex Vertex_hierarchy;
> typedef Triangulation_hierarchy::Vertex_handle
> Vertex_hierarchy_handle;
> typedef Triangulation_hierarchy::Face_handle
> Face_hierarchy_handle;
> void foo(const std::vector<Point_hierarchy> &points, const
> std::vector<Point_hierarchy> &queries) {
> Triangulation_hierarchy dh;
> dh.insert(points.begin(), points.end());
> Vertex_hierarchy_handle v = dh.nearest_vertex(queries[0]);
> Face_hierarchy_handle f = v->face();
> for (int j = 1, jend = queries.size(); j < jend; ++j) {
> v = dh.nearest_vertex(queries[j], f);
> f = v->face();
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
