- To:
- Cc: Sylvain Pion <>
- Subject: Re: [cgal-discuss] Using finger search with Delaunay Triangulation
- Date: Wed, 22 Apr 2009 13:54:46 +0200
On Wednesday 22 April 2009 13:48:01 Sylvain Pion wrote:
> Laurent Rineau (GeometryFactory) wrote:
> > On Wednesday 22 April 2009 13:29:31 Manuel Caroli wrote:
> >> Hi Manuel,
> >> you are right. Unlike point location the nearest vertex query is not
> >> overloaded by the triangulation hierarchy. Followingly the one from DT
> >> is called.
> > That is a bug, in my opinion. Would it be easy to overload the nearest
> > vertex query?
> I'm working on it.
In my opinion we should use the *template pattern* (from the book of
Gamma&al.), maybe using a CRTP, so that all methods of the triangulation that
depend on the "locate" function are accelerated in the hierarchy.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, (continued)
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Sylvain Pion, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/20/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Caroli, 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Laurent Rineau (GeometryFactory), 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Sylvain Pion, 04/22/2009
