- To:
- Subject: Re: [cgal-discuss] Using finger search with Delaunay Triangulation
- Date: Wed, 22 Apr 2009 14:24:38 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=t7p12nvXgBhq9LD6zmxUAmpZFVaET9qo0u8OltjI7hnPkSugTsNsEr2ETxwfE39AwN E3sEJHGmEu1ou9+Tgs4RUXK0l4oJCx0yZGGm2s5+qkm2CQjujtx8ymxRt4Fr0TI6XHzz P478DZuoUnaU9d8HBZ1GvC5S/ynLLF5x7YMvo=
Hi Manuel,
Thanks for your answer.
I have attached the now hopefully correct program for leveraging the
Delaunay Hierarchy in nearest neighbour queries.
Maybe it is of use to someone. Here are the juicy bits of the
program's output on my machine:
$>./test_dh_finger
Delaunay Hierarchy: finger query vs. non-finger query
n dt_no_finger dt_finger dh_no_finger dh_finger dh_speedup
2 0.550073 0.494133 0.499732 0.492765 1.014139
4 0.180180 0.143496 0.150785 0.145044 1.039580
8 0.042447 0.040908 0.048284 0.040934 1.179556
16 0.187192 0.181526 0.194100 0.180929 1.072796
32 0.072436 0.058800 0.078396 0.058778 1.333770
64 0.146741 0.123116 0.154736 0.123907 1.248807
128 0.131286 0.088024 0.136889 0.088209 1.551872
256 0.144457 0.086384 0.150825 0.086563 1.742375
512 0.186457 0.084601 0.192442 0.084808 2.269152
1024 0.215611 0.069493 0.116932 0.069964 1.671317
2048 0.297175 0.074581 0.141820 0.074778 1.896554
4096 0.383350 0.069184 0.169974 0.069191 2.456590
8192 0.527038 0.068528 0.177454 0.068764 2.580625
16384 0.708779 0.066241 0.150414 0.066194 2.272327
32768 1.047828 0.072765 0.165167 0.072591 2.275306
65536 1.481253 0.069943 0.178241 0.069794 2.553818
131072 2.243405 0.070851 0.196017 0.070185 2.792864
262144 3.585705 0.072495 0.222337 0.071803 3.096482
524288 6.232107 0.071436 0.255025 0.070398 3.622623
1048576 13.459370 0.073421 0.200260 0.072325 2.768890
-- Manuel
2009/4/22 Manuel Caroli
> Hi Manuel,
> you are right. Unlike point location the nearest vertex query is not
> overloaded by the triangulation hierarchy. Followingly the one from DT is
> called.
> Best
> Manuel
> Manuel Holtgrewe wrote:
>> Sylvain,
>> thanks for your answer. However, please have another look at the data
>> (I cut out the lesse interesting columns so the table is not wrapped.
>> Note that I am also performing a query without hints. In this case, I
>> would expect the delaunay hierarchy to be faster than the delaunay
>> triangulation.
>> Could someone compile the source file (reattached in this email) and
>> verify my results?
>> Somehow, I have the impression that the same code is called for the
>> delaunay triangulation and the delaunay hierarchy.
>> Bests,
>> Manuel
>> 2 0.505304 0.477886 0.475679 0.475234
>> 4 0.103188 0.102858 0.102885 0.101524
>> 8 0.042936 0.041076 0.043392 0.041294
>> 16 0.056725 0.047944 0.056533 0.048035
>> 32 0.075375 0.059116 0.075654 0.059563
>> 64 0.088672 0.062105 0.088614 0.062050
>> 128 0.132514 0.086989 0.132462 0.087279
>> 256 0.140531 0.078194 0.140511 0.078217
>> 512 0.175971 0.064753 0.173778 0.064725
>> 1024 0.222064 0.069129 0.221879 0.069079
>> 2048 0.299477 0.067341 0.298769 0.067386
>> 4096 0.392608 0.066532 0.393548 0.066462
>> 8192 0.547986 0.069801 0.546512 0.069839
>> 16384 0.741440 0.066260 0.741307 0.066181
>> 32768 1.080815 0.067014 1.084949 0.066969
>> 65536 1.518390 0.066989 1.512893 0.067106
>> 131072 2.312096 0.070554 2.320022 0.071241
>> 262144 3.690626 0.072124 3.677720 0.071980
>> 524288 6.416665 0.072153 6.279038 0.071597
>> 1048576 13.649976 0.072951 13.965254 0.074540
>> 2097152 27.961286 0.075513 27.911974 0.075280
>> 4194304 48.720407 0.079028 49.280193 0.078284
>> -- Manuel
>> 2009/4/20 Damian Sheehy
>>> Sylvain,
>>> Thank you for enlightening me! :)
>>> Manuel,
>>> Your non-hierarchical triangulation (dt_build in your notation) calls the
>>> dt.insert(begin, end) interface. This interface performs preprocessing to
>>> sort the points along a Hilbert curve which improves the performance of
>>> insertion. I did not factor this in when I compared computation times for
>>> the Delaunay and the Delaunay+hierarchy construction. To perform an
>>> apple-to-apple comparison of the performance of these two algorithms you
>>> should use the dt/dh.insert(Point) interface.
>>> So in summary, the hierarchy is not being leveraged during construction
>>> because the sort ensures the resulting sequence of points is in close
>>> geometric proximity; the hierarchy is not being leveraged during
>>> nearest_vertex queries because you are already providing a good starting
>>> hint. Conclusion, the hierarchy is not doing anything for you so you
>>> don't
>>> need it.
>>> Best regards,
>>> Damian
>>> On Sun, Apr 19, 2009 at 8:10 AM, Sylvain Pion
>>> wrote:
>>>> Hi Damian,
>>>> Damian Sheehy a écrit :
>>>>> For a random set of points the Delaunay hierarchy should build a
>>>>> triangulation in much less time than the conventional Delaunay without
>>>>> a
>>>>> hierarchy. The numbers do not reflect that, so something is wrong. I
>>>>> will
>>>>> run your example tomorrow and see what I get. . .
>>>> This is not true anymore in recent CGAL releases, more precisely
>>>> since the introduction of a spatial sorting preprocessing phase (BRIO).
>>>> Sylvain Pion
>>>> INRIA Sophia-Antipolis
>>>> Geometrica Project-Team
>>>> CGAL, http://cgal.org/
>>>> You are currently subscribed to cgal-discuss.
>>>> To unsubscribe or access the archives, go to
>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
test_dh_finger.cpp
Description: Binary data
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, (continued)
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Sylvain Pion, 04/19/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Damian Sheehy, 04/20/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Holtgrewe, 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Manuel Caroli, 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Laurent Rineau (GeometryFactory), 04/22/2009
- Re: [cgal-discuss] Using finger search with Delaunay Triangulation, Sylvain Pion, 04/22/2009
