cgal-discuss - Re: [cgal-discuss] orientation compatibility of triangular facets
  • To:
  • Subject: Re: [cgal-discuss] orientation compatibility of triangular facets
  • Date: Thu, 14 May 2009 15:19:21 +0200
Nizar Khalifa Sallem wrote:
So, if I pick any 2 adjacent facets in a Delaunay3D triangulation they will be consistently oriented?
No they will not. This is already due to the fact that a facet is a
std::pair<Cell_handle_int> which means that the facet can be seen
from different sides.
andreas
Nizar SALLEM
Robotics and Artificial Intelligence PhD student
LAAS-CNRS
7, Avenue Colonel Roche
31077 Toulouse CEDEX 4
FRANCE
Hi,
Is there in CGAL a way to check if two triangular facets are orientation compatible in either Triangulation or Polyhedra modules ?
In a Triangulation_2 as well as in a Polyhedron faces are consistently oriented.
This is not the case for a Complex_2_in_triangulation_3, where facets
between tetrahedra can be marked as being part of the compex.
best regards,
andreas
Thanks.
Nizar SALLEM
LAAS-CNRS
FRANCE
