- To:
- Subject: Re: [cgal-discuss] Polyhedron demo problem (bis)
- Date: Wed, 20 May 2009 10:35:36 +0200
Hello
Strange: libCGAL_Qt4.dylib is not in that list! Have you build CGAL with Qt4 support?
Of course, Qt4 is on (but Qt3 is off like under windows and linux), you can
see that in cmake-gui.txt.
Here is the logs with -v (make cgal and make Polyhedron).
Thank you for your help.
Laurent Rineau (GeometryFactory) a écrit :
On Tuesday 19 May 2009 14:19:42 Martial TOLA (CNRS-Liris) wrote:liristvn:Polyhedron mt$ make
So, now for MacOsX :-)
No QT headers and QT libs in /opt/local.
But, to be sure to avoid conflicts I erase all my macports and reinstall
only what it is necessary (boost, gmp and mpfr).
But ----> same error during Polyhedron link :
I have no idea for the moment. Using cmake-gui or ccmake, please add "-v" to CMAKE_CXX_FLAGS and CMAKE_EXE_LINKER_FLAGS, and rerun the compilation. I would need to see what appears after "[100%] Building CXX object demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o" and after "Linking CXX executable Polyhedron_3".
cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build && "/Applications/CMake
2.6-3.app/Contents/bin/cmake" -H/Users/mt/_lib_autres_que_macports/CGAL-3.4
-B/Users/mt/_lib_autres_que_macports/CGAL-3.4/build --check-build-system
CMakeFiles/Makefile.cmake 0
2.6-3.app/Contents/bin/cmake" -E cmake_progress_start
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/demo/Polyhedron/CMakeFiles/progress.make
cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build && make -f
CMakeFiles/Makefile2 demo/Polyhedron/all
make -f demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/build.make
demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/depend
"/Applications/CMake 2.6-3.app/Contents/bin/cmake" -E cmake_progress_report
[ 0%] Generating qrc_Polyhedron_3.cxx
cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build/demo/Polyhedron &&
/Developer/Tools/Qt/rcc -name Polyhedron_3 -o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/demo/Polyhedron/qrc_Polyhedron_3.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/Polyhedron_3.qrc
[ 0%] Generating MainWindow_moc.cpp
/Developer/Tools/Qt/moc
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/./include
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/include
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/include
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/demo/Polyhedron
-I/opt/local/include -I/usr/include
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/optimized
-I/Library/Frameworks/QtCore.framework
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/debug
-I/Library/Frameworks/QtOpenGL.framework/Headers
-I/Library/Frameworks/QtScript.framework/Headers
-I/Library/Frameworks/QtGui.framework/Headers
-I/Library/Frameworks/QtXml.framework/Headers
-I/Library/Frameworks/QtCore.framework/Headers -I/usr/local/include -DQT_DLL
-DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CORE_LIB
-DCGAL_USE_TAUCS -DLAPACK_USE_F2C -DCGAL_USE_F2C -DBLAS_USE_F2C
-DCGAL_USE_F2C -DCGAL_TAUCS_ENABLED -o MainWindow_moc.cpp
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/MainWindow.h
[ 0%] Generating Scene_moc.cpp
-DCGAL_USE_F2C -DCGAL_TAUCS_ENABLED -o Scene_moc.cpp
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/Scene.h
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles 90
[100%] Generating Viewer_moc.cpp
-DCGAL_USE_F2C -DCGAL_TAUCS_ENABLED -o Viewer_moc.cpp
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/Viewer.h
[100%] Generating ui_MainWindow.h
/Developer/Tools/Qt/uic -o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/demo/Polyhedron/ui_MainWindow.h
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/MainWindow.ui
2.6-3.app/Contents/bin/cmake" -E cmake_depends "Unix Makefiles"
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/DependInfo.cmake
--color=
Scanning dependencies of target Polyhedron_3
/usr/bin/c++ -DQT_DLL -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB
-DQT_XML_LIB -DQT_CORE_LIB -DCGAL_USE_TAUCS -DLAPACK_USE_F2C -DCGAL_USE_F2C
-DBLAS_USE_F2C -DCGAL_USE_F2C -DCGAL_TAUCS_ENABLED -DQT_NO_DEBUG
-frounding-math -v -O3 -DNDEBUG
-F/Library/Frameworks
-I/Library/Frameworks/QtCore.framework/Headers -F/usr/lib -o
CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/Polyhedron_3.cpp
Using built-in specs.
Target: i686-apple-darwin9
Configured with: /var/tmp/gcc/gcc-5484~1/src/configure --disable-checking
-enable-werror --prefix=/usr --mandir=/share/man
--enable-languages=c,objc,c++,obj-c++
--program-transform-name=/^[cg][^.-]*$/s/$/-4.0/
--with-gxx-include-dir=/include/c++/4.0.0 --with-slibdir=/usr/lib
--build=i686-apple-darwin9 --with-arch=apple --with-tune=generic
--host=i686-apple-darwin9 --target=i686-apple-darwin9
Thread model: posix
gcc version 4.0.1 (Apple Inc. build 5484)
/usr/libexec/gcc/i686-apple-darwin9/4.0.1/cc1plus -quiet -v
-I/Library/Frameworks/QtCore.framework/Headers -F/usr/lib -D__DYNAMIC__
-DQT_DLL -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB -DQT_XML_LIB
-DQT_CORE_LIB -DCGAL_USE_TAUCS -DLAPACK_USE_F2C -DCGAL_USE_F2C -DBLAS_USE_F2C
-DCGAL_USE_F2C -DCGAL_TAUCS_ENABLED -DQT_NO_DEBUG -DNDEBUG
-fPIC -quiet -dumpbase Polyhedron_3.cpp -mmacosx-version-min=10.5.6
-mtune=generic -march=apple -auxbase-strip
CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o -O3 -version -frounding-math
-D__private_extern__=extern -o
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//cccARyx7.s
ignoring nonexistent directory
"/usr/lib/gcc/i686-apple-darwin9/4.0.1/../../../../i686-apple-darwin9/include"
"/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/optimized"
ignoring duplicate directory "/Library/Frameworks"
as it is a non-system directory that duplicates a system directory
"/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron/debug"
#include "..." search starts here:
#include <...> search starts here:
/opt/local/include
/usr/lib (framework directory)
/usr/include/c++/4.0.0
/usr/include/c++/4.0.0/i686-apple-darwin9
/usr/include/c++/4.0.0/backward
/usr/local/include
/usr/lib/gcc/i686-apple-darwin9/4.0.1/include
/usr/include
/System/Library/Frameworks (framework directory)
End of search list.
GNU C++ version 4.0.1 (Apple Inc. build 5484) (i686-apple-darwin9)
compiled by GNU C version 4.0.1 (Apple Inc. build 5484).
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
Compiler executable checksum: 26a07d3b4fce49bea6ac55e876df1aa9
/usr/libexec/gcc/i686-apple-darwin9/4.0.1/as -arch i386
-force_cpusubtype_ALL -o CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o
demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o
CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o -c
Thread model: posix
-fPIC -quiet -dumpbase qrc_Polyhedron_3.cxx -mmacosx-version-min=10.5.6
CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o -O3 -version -frounding-math
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//cc2HeMBs.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o
"/Applications/CMake 2.6-3.app/Contents/bin/cmake" -E cmake_link_script
CMakeFiles/Polyhedron_3.dir/link.txt --verbose=1
/usr/bin/c++ -frounding-math -v -O3 -DNDEBUG -Wl,-search_paths_first
-headerpad_max_install_names -fPIC -v
CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o -o Polyhedron_3 -F/usr/lib
-L/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/lib -L/opt/local/lib
../../lib/libCGAL.dylib /opt/local/lib/libgmpxx.dylib
/opt/local/lib/libmpfr.dylib /opt/local/lib/libgmp.dylib
/opt/local/lib/libboost_thread-mt.dylib /usr/local/lib/libtaucs.a
/usr/local/lib/libmetis.a -framework Accelerate /usr/local/lib/libf2c.a
-framework Accelerate /usr/local/lib/libf2c.a -framework QtOpenGL -framework
OpenGL -framework AGL -framework QtScript -framework QtGui -framework Carbon
-framework AppKit -framework QtXml -framework QtCore /usr/lib/libz.dylib
-framework ApplicationServices ../../lib/libCGAL.dylib
/opt/local/lib/libgmpxx.dylib /opt/local/lib/libmpfr.dylib
/opt/local/lib/libgmp.dylib /opt/local/lib/libboost_thread-mt.dylib
-framework QGLViewer -framework OpenGL -framework AGL
/usr/local/lib/libtaucs.a /usr/local/lib/libmetis.a ../../lib/libCGAL.dylib
-framework ApplicationServices -framework QGLViewer -framework OpenGL
-framework AGL
Thread model: posix
/usr/libexec/gcc/i686-apple-darwin9/4.0.1/collect2 -dynamic -arch i386
-headerpad_max_install_names -macosx_version_min 10.5.6
-weak_reference_mismatches non-weak -o Polyhedron_3 -lcrt1.10.5.o
-L/usr/lib/i686-apple-darwin9/4.0.1 -L/usr/lib/gcc/i686-apple-darwin9/4.0.1
-L/usr/lib/gcc/i686-apple-darwin9/4.0.1/../../../i686-apple-darwin9/4.0.1
-L/usr/lib/gcc/i686-apple-darwin9/4.0.1/../../.. -search_paths_first
CMakeFiles/Polyhedron_3.dir/qrc_Polyhedron_3.o ../../lib/libCGAL.dylib
/usr/local/lib/libtaucs.a /usr/local/lib/libmetis.a -framework Accelerate
/usr/local/lib/libf2c.a -framework Accelerate /usr/local/lib/libf2c.a
-framework QtOpenGL -framework OpenGL -framework AGL -framework QtScript
-framework QtGui -framework Carbon -framework AppKit -framework QtXml
-framework QtCore /usr/lib/libz.dylib -framework ApplicationServices
/opt/local/lib/libboost_thread-mt.dylib -framework QGLViewer -framework
OpenGL -framework AGL /usr/local/lib/libtaucs.a /usr/local/lib/libmetis.a
/opt/local/lib/libboost_thread-mt.dylib -framework Accelerate
/usr/local/lib/libf2c.a -framework QtOpenGL -framework OpenGL -framework AGL
-framework QtScript -framework QtGui -framework Carbon -framework AppKit
-framework QtXml -framework QtCore /usr/lib/libz.dylib -framework
ApplicationServices -framework QGLViewer -framework OpenGL -framework AGL
-lstdc++ -lgcc_s.10.5 -lgcc -lSystem -F/usr/lib
ld warning: duplicate dylib /opt/local/lib/libboost_thread-mt.dylib
ld warning: duplicate dylib ../../lib/libCGAL.dylib
ld warning: duplicate dylib /opt/local/lib/libgmpxx.dylib
ld warning: duplicate dylib /opt/local/lib/libmpfr.dylib
ld warning: duplicate dylib /opt/local/lib/libgmp.dylib
Undefined symbols:
"CGAL::Qt::DemosMainWindow::staticMetaObject", referenced from:
MainWindow::staticMetaObject in Polyhedron_3.o
"vtable for CGAL::Qt::DemosMainWindow", referenced from:
__ZTVN4CGAL2Qt15DemosMainWindowE$non_lazy_ptr in Polyhedron_3.o
"CGAL::Qt::DemosMainWindow::addToRecentFiles(QString)", referenced from:
MainWindow::open(QString) in Polyhedron_3.o
"CGAL::Qt::DemosMainWindow::addAboutDemo(QString, QMenu*)", referenced from:
MainWindow::MainWindow(QWidget*)in Polyhedron_3.o
"qInitResources_Triangulation_2()", referenced from:
_main in Polyhedron_3.o
"typeinfo for CGAL::Qt::DemosMainWindow", referenced from:
typeinfo for MainWindowin Polyhedron_3.o
"qInitResources_CGAL()", referenced from:
"CGAL::Qt::DemosMainWindow::qt_metacast(char const*)", referenced from:
MainWindow::qt_metacast(char const*)in Polyhedron_3.o
"CGAL::Qt::DemosMainWindow::addRecentFiles(QMenu*, QAction*)", referenced
"CGAL::Qt::DemosMainWindow::DemosMainWindow(QWidget*,
QFlags<Qt::WindowType>)", referenced from:
"qInitResources_Input()", referenced from:
"qInitResources_File()", referenced from:
"CGAL::Qt::DemosMainWindow::readState(QString,
QFlags<CGAL::Qt::DemosMainWindow::Option>)", referenced from:
MainWindow::readSettings() in Polyhedron_3.o
MainWindow::qt_metacall(QMetaObject::Call, int, void**)in Polyhedron_3.o
"CGAL::Qt::DemosMainWindow::qt_metacall(QMetaObject::Call, int, void**)",
referenced from:
"CGAL::Qt::DemosMainWindow::addAboutCGAL(QMenu*)", referenced from:
"CGAL::Qt::DemosMainWindow::writeState(QString)", referenced from:
MainWindow::writeSettings() in Polyhedron_3.o
MainWindow::quit() in Polyhedron_3.o
MainWindow::closeEvent(QCloseEvent*) in Polyhedron_3.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[2]: *** [demo/Polyhedron/Polyhedron_3] Error 1
make[1]: *** [demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/all] Error 2
make: *** [all] Error 2
liristvn:Polyhedron mt$The C compiler identification is GNU
The CXX compiler identification is GNU
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=4
CGAL_BUILD_VERSION=
CGAL_SONAME_VERSION=3
CGAL_SOVERSION =3.0.0
CGAL_REFERENCE_CACHE_DIR=
Building shared libraries
CMake Warning (dev) at CMakeLists.txt:88 (include):
Policy CMP0011 is not set: Included scripts do automatic cmake_policy PUSH
and POP. Run "cmake --help-policy CMP0011" for policy details. Use the
cmake_policy command to set the policy and suppress this warning.
The included script
/Users/mt/_lib_autres_que_macports/CGAL-3.4/cmake/modules/CGAL_Common.cmake
affects policy settings. CMake is implying the NO_POLICY_SCOPE option for
compatibility, so the effects are applied to the including context.
This warning is for project developers. Use -Wno-dev to suppress it.
Targetting Unix Makefiles
Using /usr/bin/c++ compiler.
DARWIN_VERSION=9
Mac Leopard detected
USING CMake version: 2.6.3
System: Darwin
USING GCC_VERSION = '4.0.1 (Apple Inc. build 5484)'
Using gcc version 4 or later. Adding -frounding-math
Build type: Release
USING CXXFLAGS = ' -frounding-math -v -O3 -DNDEBUG'
USING LDFLAGS = '
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
GMPXX include: /opt/local/include
GMPXX libraries: /opt/local/lib/libgmpxx.dylib
GMP include: /opt/local/include
GMP libraries: /opt/local/lib/libgmp.dylib
GMP definitions:
USING GMP_VERSION = '4.3.1'
MPFR include: /opt/local/include
MPFR libraries: /opt/local/lib/libmpfr.dylib
MPFR definitions:
USING MPFR_VERSION = '2.4.1'
Boost include: /opt/local/include
Boost libraries: /opt/local/lib/libboost_thread-mt.dylib
Boost definitions:
USING BOOST_VERSION = '1.38.0'
CMAKE_INSTALL_PREFIX=/usr/local
OpenGL include: /System/Library/Frameworks/OpenGL.framework
OpenGL libraries:
/System/Library/Frameworks/AGL.framework;/System/Library/Frameworks/OpenGL.framework
USING ZLIB_VERSION = '1.2.3'
ZLib include: /usr/include
ZLib libraries: /usr/lib/libz.dylib
USING QT4_VERSION = '4.5.1'
OpenGL libraries:
OpenGL definitions:
Qt4 include: /usr/include
Qt4 libraries:
optimized;/Library/Frameworks/QtOpenGL.framework;debug;/Library/Frameworks/QtOpenGL.framework;-framework
OpenGL -framework
AGL;optimized;/Library/Frameworks/QtGui.framework;debug;/Library/Frameworks/QtGui.framework;-framework
Carbon;-framework
AppKit;optimized;/Library/Frameworks/QtCore.framework;debug;/Library/Frameworks/QtCore.framework;/usr/lib/libz.dylib;-framework
ApplicationServices
Qt4 definitions: -DQT_DLL
moc executable: /Developer/Tools/Qt/moc
uic executable: /Developer/Tools/Qt/uic
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Algebraic_foundations
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Alpha_shapes_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Alpha_shapes_3 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Apollonius_graph_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Approximate_min_ellipsoid_d
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Arrangement_on_surface_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/BGL_arrangement_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/BGL_polyhedron_3 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/BGL_triangulation_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Boolean_set_operations_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Box_intersection_d
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/CGALimageIO
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Circular_kernel_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Circular_kernel_3 example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Circulator
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Convex_hull_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Convex_hull_3 example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Core example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Envelope_2
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Envelope_3
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Filtered_kernel example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Generator
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/HalfedgeDS
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Interpolation example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Interval_skip_list
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Jet_fitting_3 example
LAPACK include:
LAPACK definitions: -DLAPACK_USE_F2C
LAPACK libraries:
/System/Library/Frameworks/Accelerate.framework;/usr/local/lib/libf2c.a
LAPACK link flags:
BLAS include:
BLAS definitions: -DBLAS_USE_F2C
BLAS libraries:
BLAS link flags:
Boost.ProgramOptions library: /opt/local/lib/libboost_program_options-mt.dylib
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Kernel_23
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Kinetic_data_structures
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Kinetic_framework example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Largest_empty_rect_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Matrix_search example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Mesh_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Min_annulus_d example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Min_circle_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Min_ellipse_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Min_quadrilateral_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Min_sphere_d example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Min_sphere_of_spheres_d
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Minkowski_sum_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Modular_arithmetic
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Nef_2
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Nef_3
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Nef_S2
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/PDB example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Partition_2
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Point_set_2
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Polygon
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Polyhedron
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Polyhedron_IO example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Polynomial
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Polynomial_kernel example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Polytope_distance_d
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Principal_component_analysis
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Profiling_tools example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/QP_solver
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/RangeSegmentTrees example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Ridges_3
example
LAPACK include:
LAPACK libraries:
LAPACK link flags:
BLAS include:
BLAS libraries:
BLAS link flags:
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/STL_Extension example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Segment_Delaunay_graph_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Skin_surface_3 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Snap_rounding_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Spatial_searching example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Spatial_sorting example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Straight_skeleton_2
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Stream_lines_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Subdivision_method_3
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Surface_mesh_parameterization
example
USING CXXFLAGS = ' -frounding-math -v -O3 -DNDEBUG -fno-strict-aliasing'
USING EXEFLAGS = '-v '
TAUCS include: /usr/local/include
TAUCS definitions:
TAUCS libraries: /usr/local/lib/libtaucs.a;/usr/local/lib/libmetis.a
LAPACK include:
LAPACK libraries:
LAPACK link flags:
BLAS include:
BLAS libraries:
BLAS link flags:
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Surface_mesh_simplification
example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Surface_mesher example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Triangulation_2 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Triangulation_3 example
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Voronoi_diagram_2 example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/examples/Width_3
example
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Alpha_shapes_2
demo
NOTICE: The CGAL_Qt3 library was not configured. Please configure CGAL using
WITH_CGAL_Qt3=ON.
NOTICE: This demo requires CGAL and Qt3, and will not be compiled.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Alpha_shapes_3
demo
Found QGLViewer: /usr/lib/QGLViewer.framework
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Apollonius_graph_2 demo
WITH_CGAL_Qt3=ON.
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Arrangement_on_surface_2 demo
WITH_CGAL_Qt3=ON.
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Boolean_set_operations_2 demo
WITH_CGAL_Qt3=ON.
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Circular_kernel_2 demo
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Circular_kernel_3 demo
WITH_CGAL_Qt3=ON.
NOTICE: This demo requires Qt3 and the CGAL Qt3 library, and will not be
compiled.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Convex_hull_2
demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Convex_hull_3
demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Convex_hull_d
demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Envelope_3 demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Generator demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Geomview demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/GraphicsView
demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Interpolation
demo
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Kinetic_data_structures demo
WITH_CGAL_Qt3=ON.
compiled.
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Largest_empty_rect_2 demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Matrix_search
demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Mesh_2 demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Min_circle_2
demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Min_ellipse_2
demo
WITH_CGAL_Qt3=ON.
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Min_quadrilateral_2 demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Nef_2 demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Nef_3 demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Nef_S2 demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/PDB demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Partition_2 demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polygon demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron demo
TAUCS definitions:
LAPACK include:
LAPACK libraries:
LAPACK link flags:
BLAS include:
BLAS libraries:
BLAS link flags:
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Polyhedron_IO
demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Robustness demo
WITH_CGAL_Qt3=ON.
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Segment_Delaunay_graph_2 demo
WITH_CGAL_Qt3=ON.
NOTICE: This demo requires CGAL,, Core, and Qt3, and will not be compiled.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Snap_rounding_2
demo
WITH_CGAL_Qt3=ON.
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Spatial_searching demo
WITH_CGAL_Qt3=ON.
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Straight_skeleton_2 demo
WITH_CGAL_Qt3=ON.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Stream_lines_2
demo
WITH_CGAL_Qt3=ON.
NOTICE: This demo requires CGAL, Qt3, and OpenGL, and will not be compiled.
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Surface_mesher
demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Triangulation_2
demo
Configuring /Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Triangulation_3
demo
Configuring
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/Voronoi_diagram_2 demo
WITH_CGAL_Qt3=ON.
Configuring done
Generating done
liristvn:build mt$ make
"/Applications/CMake 2.6-3.app/Contents/bin/cmake" -E cmake_progress_start
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles/progress.make
make -f CMakeFiles/Makefile2 all
make -f src/CGAL/CMakeFiles/CGAL.dir/build.make
src/CGAL/CMakeFiles/CGAL.dir/depend
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGAL
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGAL
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGAL/CMakeFiles/CGAL.dir/DependInfo.cmake
--color=
Scanning dependencies of target CGAL
[ 0%] Building CXX object src/CGAL/CMakeFiles/CGAL.dir/all_files.o
cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGAL && /usr/bin/c++
-DCGAL_EXPORTS -frounding-math -v -O3 -DNDEBUG -fPIC
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/include -I/opt/local/include
-o CMakeFiles/CGAL.dir/all_files.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGAL/all_files.cpp
Thread model: posix
-D__DYNAMIC__ -DCGAL_EXPORTS -DNDEBUG
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGAL/all_files.cpp -fPIC
-quiet -dumpbase all_files.cpp -mmacosx-version-min=10.5.6 -mtune=generic
-march=apple -auxbase-strip CMakeFiles/CGAL.dir/all_files.o -O3 -version
-frounding-math -fPIC -D__private_extern__=extern -o
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccBNH3Pg.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL.dir/all_files.o
Linking CXX shared library ../../lib/libCGAL.dylib
CMakeFiles/CGAL.dir/link.txt --verbose=1
/usr/bin/c++ -frounding-math -v -O3 -DNDEBUG -dynamiclib
-compatibility_version 3.0.0 -current_version 3.0.0 -o
../../lib/libCGAL.3.0.0.dylib -install_name
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/lib/libCGAL.3.dylib
CMakeFiles/CGAL.dir/all_files.o /opt/local/lib/libgmpxx.dylib
Thread model: posix
/usr/libexec/gcc/i686-apple-darwin9/4.0.1/collect2 -dynamic -dylib
-dylib_compatibility_version 3.0.0 -dylib_current_version 3.0.0 -arch i386
-dylib_install_name
-weak_reference_mismatches non-weak -o ../../lib/libCGAL.3.0.0.dylib
-ldylib1.10.5.o -L/usr/lib/i686-apple-darwin9/4.0.1
-L/usr/lib/gcc/i686-apple-darwin9/4.0.1/../../.. -dylib_file
/opt/local/lib/libboost_thread-mt.dylib -lstdc++ -lgcc_s.10.5 -lgcc -lSystem
"/Applications/CMake 2.6-3.app/Contents/bin/cmake" -E cmake_symlink_library
../../lib/libCGAL.3.0.0.dylib ../../lib/libCGAL.3.dylib
[ 0%] Built target CGAL
make -f src/CGALCore/CMakeFiles/CGAL_Core.dir/build.make
src/CGALCore/CMakeFiles/CGAL_Core.dir/depend
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALCore
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALCore
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALCore/CMakeFiles/CGAL_Core.dir/DependInfo.cmake
--color=
Scanning dependencies of target CGAL_Core
[ 0%] Building CXX object src/CGALCore/CMakeFiles/CGAL_Core.dir/all_files.o
cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALCore &&
/usr/bin/c++ -DCGAL_Core_EXPORTS -frounding-math -v -O3 -DNDEBUG -fPIC
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALCore
-I/opt/local/include -o CMakeFiles/CGAL_Core.dir/all_files.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALCore/all_files.cpp
Thread model: posix
-I/opt/local/include -D__DYNAMIC__ -DCGAL_Core_EXPORTS -DNDEBUG
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALCore/all_files.cpp -fPIC
-march=apple -auxbase-strip CMakeFiles/CGAL_Core.dir/all_files.o -O3 -version
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccElYNbV.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Core.dir/all_files.o
Linking CXX shared library ../../lib/libCGAL_Core.dylib
CMakeFiles/CGAL_Core.dir/link.txt --verbose=1
../../lib/libCGAL_Core.3.0.0.dylib -install_name
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/lib/libCGAL_Core.3.dylib
/opt/local/lib/libboost_thread-mt.dylib ../../lib/libCGAL.dylib
../../lib/libCGAL.dylib ../../lib/libCGAL.dylib /opt/local/lib/libgmpxx.dylib
Thread model: posix
-dylib_install_name
-weak_reference_mismatches non-weak -o ../../lib/libCGAL_Core.3.0.0.dylib
-ldylib1.10.5.o -L/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/lib
-L/opt/local/lib -L/usr/lib/i686-apple-darwin9/4.0.1
CMakeFiles/CGAL_Core.dir/all_files.o ../../lib/libCGAL.dylib
/opt/local/lib/libboost_thread-mt.dylib /opt/local/lib/libgmpxx.dylib
../../lib/libCGAL_Core.3.0.0.dylib ../../lib/libCGAL_Core.3.dylib
[ 0%] Built target CGAL_Core
make -f src/CGALimageIO/CMakeFiles/CGAL_ImageIO.dir/build.make
src/CGALimageIO/CMakeFiles/CGAL_ImageIO.dir/depend
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALimageIO
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALimageIO
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALimageIO/CMakeFiles/CGAL_ImageIO.dir/DependInfo.cmake
--color=
Scanning dependencies of target CGAL_ImageIO
src/CGALimageIO/CMakeFiles/CGAL_ImageIO.dir/all_files.o
cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALimageIO &&
/usr/bin/c++ -DCGAL_USE_ZLIB -DCGAL_ImageIO_EXPORTS -frounding-math -v -O3
-DNDEBUG -fPIC -I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/include
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALimageIO
-I/opt/local/include -o CMakeFiles/CGAL_ImageIO.dir/all_files.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALimageIO/all_files.cpp
Thread model: posix
-I/opt/local/include -D__DYNAMIC__ -DCGAL_USE_ZLIB -DCGAL_ImageIO_EXPORTS
-DNDEBUG
-fPIC -quiet -dumpbase all_files.cpp -mmacosx-version-min=10.5.6
CMakeFiles/CGAL_ImageIO.dir/all_files.o -O3 -version -frounding-math -fPIC
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccuj5HZ4.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_ImageIO.dir/all_files.o
Linking CXX shared library ../../lib/libCGAL_ImageIO.dylib
CMakeFiles/CGAL_ImageIO.dir/link.txt --verbose=1
../../lib/libCGAL_ImageIO.3.0.0.dylib -install_name
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/lib/libCGAL_ImageIO.3.dylib
-framework AGL -framework OpenGL /usr/lib/libz.dylib ../../lib/libCGAL.dylib
Thread model: posix
-dylib_install_name
-weak_reference_mismatches non-weak -o ../../lib/libCGAL_ImageIO.3.0.0.dylib
CMakeFiles/CGAL_ImageIO.dir/all_files.o ../../lib/libCGAL.dylib
/opt/local/lib/libboost_thread-mt.dylib -framework AGL -framework OpenGL
/usr/lib/libz.dylib ../../lib/libCGAL.dylib /opt/local/lib/libgmpxx.dylib
/usr/lib/libz.dylib -lstdc++ -lgcc_s.10.5 -lgcc -lSystem
../../lib/libCGAL_ImageIO.3.0.0.dylib ../../lib/libCGAL_ImageIO.3.dylib
[ 0%] Built target CGAL_ImageIO
make -f src/CGALPDB/CMakeFiles/CGAL_PDB.dir/build.make
src/CGALPDB/CMakeFiles/CGAL_PDB.dir/depend
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALPDB
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALPDB
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALPDB/CMakeFiles/CGAL_PDB.dir/DependInfo.cmake
--color=
Scanning dependencies of target CGAL_PDB
[ 0%] Building CXX object src/CGALPDB/CMakeFiles/CGAL_PDB.dir/all_files.o
cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALPDB &&
/usr/bin/c++ -DCGAL_PDB_EXPORTS -frounding-math -v -O3 -DNDEBUG -fPIC
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALPDB
-I/opt/local/include -o CMakeFiles/CGAL_PDB.dir/all_files.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALPDB/all_files.cpp
Thread model: posix
-I/opt/local/include -D__DYNAMIC__ -DCGAL_PDB_EXPORTS -DNDEBUG
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALPDB/all_files.cpp -fPIC
-march=apple -auxbase-strip CMakeFiles/CGAL_PDB.dir/all_files.o -O3 -version
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//cc66elOj.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_PDB.dir/all_files.o
Linking CXX shared library ../../lib/libCGAL_PDB.dylib
CMakeFiles/CGAL_PDB.dir/link.txt --verbose=1
../../lib/libCGAL_PDB.3.0.0.dylib -install_name
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/lib/libCGAL_PDB.3.dylib
Thread model: posix
-dylib_install_name
-weak_reference_mismatches non-weak -o ../../lib/libCGAL_PDB.3.0.0.dylib
CMakeFiles/CGAL_PDB.dir/all_files.o ../../lib/libCGAL.dylib
../../lib/libCGAL_PDB.3.0.0.dylib ../../lib/libCGAL_PDB.3.dylib
[ 0%] Built target CGAL_PDB
make -f src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/build.make
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/depend
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles 5
[ 20%] Generating qrc_Triangulation_2.cxx
cd /Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4 &&
/Developer/Tools/Qt/rcc -name Triangulation_2 -o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/qrc_Triangulation_2.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/icons/Triangulation_2.qrc
[ 20%] Generating __/__/include/CGAL/Qt/moc_GraphicsViewNavigation.cxx
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/../../include
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/optimized
-I/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/debug
-I/Library/Frameworks/QtCore.framework/Headers -DQT_DLL -DQT_OPENGL_LIB
-DQT_GUI_LIB -DQT_CORE_LIB -o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/__/__/include/CGAL/Qt/moc_GraphicsViewNavigation.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/include/CGAL/Qt/GraphicsViewNavigation.h
[ 20%] Generating __/__/include/CGAL/Qt/moc_DemosMainWindow.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/__/__/include/CGAL/Qt/moc_DemosMainWindow.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/include/CGAL/Qt/DemosMainWindow.h
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles 4
[ 40%] Generating __/__/include/CGAL/Qt/moc_GraphicsItem.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/__/__/include/CGAL/Qt/moc_GraphicsItem.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/include/CGAL/Qt/GraphicsItem.h
[ 40%] Generating __/__/include/CGAL/Qt/moc_GraphicsViewInput.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/__/__/include/CGAL/Qt/moc_GraphicsViewInput.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/include/CGAL/Qt/GraphicsViewInput.h
[ 40%] Generating qrc_CGAL.cxx
/Developer/Tools/Qt/rcc -name CGAL -o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/qrc_CGAL.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/resources/CGAL.qrc
[ 40%] Generating qrc_Input.cxx
/Developer/Tools/Qt/rcc -name Input -o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/qrc_Input.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/icons/Input.qrc
[ 40%] Generating qrc_File.cxx
/Developer/Tools/Qt/rcc -name File -o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/qrc_File.cxx
/Users/mt/_lib_autres_que_macports/CGAL-3.4/demo/icons/File.qrc
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/DependInfo.cmake
--color=
Scanning dependencies of target CGAL_Qt4
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles 1
[ 60%] Building CXX object src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/debug.o
/usr/bin/c++ -DQT_DLL -DQT_OPENGL_LIB -DQT_GUI_LIB -DQT_CORE_LIB
-DQT_NO_DEBUG -DCGAL_Qt4_EXPORTS -frounding-math -v -O3 -DNDEBUG -fPIC
-I/Library/Frameworks/QtCore.framework/Headers -o
CMakeFiles/CGAL_Qt4.dir/debug.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/debug.cpp
Thread model: posix
-I/Library/Frameworks/QtCore.framework/Headers -D__DYNAMIC__ -DQT_DLL
-DQT_OPENGL_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_NO_DEBUG -DCGAL_Qt4_EXPORTS
-DNDEBUG /Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/debug.cpp
-fPIC -quiet -dumpbase debug.cpp -mmacosx-version-min=10.5.6 -mtune=generic
-march=apple -auxbase-strip CMakeFiles/CGAL_Qt4.dir/debug.o -O3 -version
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccPwffVR.s
"/Users/mt/_lib_autres_que_macports/CGAL-3.4/include"
"/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/optimized"
"/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/debug"
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/debug.o
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/GraphicsViewNavigation.o
CMakeFiles/CGAL_Qt4.dir/GraphicsViewNavigation.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/GraphicsViewNavigation.cpp
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase GraphicsViewNavigation.cpp
-mmacosx-version-min=10.5.6 -mtune=generic -march=apple -auxbase-strip
CMakeFiles/CGAL_Qt4.dir/GraphicsViewNavigation.o -O3 -version -frounding-math
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccVYSpnS.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/GraphicsViewNavigation.o
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/GraphicsViewPolylineInput.o
CMakeFiles/CGAL_Qt4.dir/GraphicsViewPolylineInput.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/GraphicsViewPolylineInput.cpp
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase GraphicsViewPolylineInput.cpp
CMakeFiles/CGAL_Qt4.dir/GraphicsViewPolylineInput.o -O3 -version
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccRMLI27.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/GraphicsViewPolylineInput.o
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/DemosMainWindow.o
CMakeFiles/CGAL_Qt4.dir/DemosMainWindow.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/DemosMainWindow.cpp
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase DemosMainWindow.cpp -mmacosx-version-min=10.5.6
CMakeFiles/CGAL_Qt4.dir/DemosMainWindow.o -O3 -version -frounding-math -fPIC
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccEtgqmO.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/DemosMainWindow.o
[ 60%] Building CXX object src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/utility.o
CMakeFiles/CGAL_Qt4.dir/utility.o -c
/Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/utility.cpp
Thread model: posix
-DNDEBUG /Users/mt/_lib_autres_que_macports/CGAL-3.4/src/CGALQt4/utility.cpp
-fPIC -quiet -dumpbase utility.cpp -mmacosx-version-min=10.5.6 -mtune=generic
-march=apple -auxbase-strip CMakeFiles/CGAL_Qt4.dir/utility.o -O3 -version
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccZUE6sq.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/utility.o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles 2
[ 80%] Building CXX object
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewNavigation.o
CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewNavigation.o -c
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase moc_GraphicsViewNavigation.cxx
-O3 -version -frounding-math -fPIC -D__private_extern__=extern -o
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccB7pcId.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_DemosMainWindow.o
CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_DemosMainWindow.o -c
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase moc_DemosMainWindow.cxx -mmacosx-version-min=10.5.6
CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_DemosMainWindow.o -O3
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccHDESGh.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsItem.o
CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsItem.o -c
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase moc_GraphicsItem.cxx -mmacosx-version-min=10.5.6
CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsItem.o -O3 -version
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//cc06EYF7.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewInput.o
CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewInput.o -c
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase moc_GraphicsViewInput.cxx -mmacosx-version-min=10.5.6
CMakeFiles/CGAL_Qt4.dir/__/__/include/CGAL/Qt/moc_GraphicsViewInput.o -O3
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccv697WQ.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
[ 80%] Building CXX object src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/qrc_CGAL.o
CMakeFiles/CGAL_Qt4.dir/qrc_CGAL.o -c
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase qrc_CGAL.cxx -mmacosx-version-min=10.5.6
-mtune=generic -march=apple -auxbase-strip CMakeFiles/CGAL_Qt4.dir/qrc_CGAL.o
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccvzbPcb.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/qrc_CGAL.o
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles 3
[100%] Building CXX object src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/qrc_Input.o
CMakeFiles/CGAL_Qt4.dir/qrc_Input.o -c
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase qrc_Input.cxx -mmacosx-version-min=10.5.6
CMakeFiles/CGAL_Qt4.dir/qrc_Input.o -O3 -version -frounding-math -fPIC
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccD2e16e.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/qrc_Input.o
[100%] Building CXX object src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/qrc_File.o
CMakeFiles/CGAL_Qt4.dir/qrc_File.o -c
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase qrc_File.cxx -mmacosx-version-min=10.5.6
-mtune=generic -march=apple -auxbase-strip CMakeFiles/CGAL_Qt4.dir/qrc_File.o
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccpUSOMx.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/qrc_File.o
src/CGALQt4/CMakeFiles/CGAL_Qt4.dir/qrc_Triangulation_2.o
CMakeFiles/CGAL_Qt4.dir/qrc_Triangulation_2.o -c
Thread model: posix
-DNDEBUG
-fPIC -quiet -dumpbase qrc_Triangulation_2.cxx -mmacosx-version-min=10.5.6
CMakeFiles/CGAL_Qt4.dir/qrc_Triangulation_2.o -O3 -version -frounding-math
/var/folders/9U/9Uh-d3dcFh8-NGG5WEJRDk+++TI/-Tmp-//ccv5O0Pt.s
/opt/local/include
/usr/local/include
/usr/include
End of search list.
-force_cpusubtype_ALL -o CMakeFiles/CGAL_Qt4.dir/qrc_Triangulation_2.o
Linking CXX shared library ../../lib/libCGAL_Qt4.dylib
CMakeFiles/CGAL_Qt4.dir/link.txt --verbose=1
../../lib/libCGAL_Qt4.3.0.0.dylib -install_name
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/lib/libCGAL_Qt4.3.dylib
CMakeFiles/CGAL_Qt4.dir/DemosMainWindow.o CMakeFiles/CGAL_Qt4.dir/utility.o
CMakeFiles/CGAL_Qt4.dir/qrc_CGAL.o CMakeFiles/CGAL_Qt4.dir/qrc_Input.o
-framework QtOpenGL -framework OpenGL -framework AGL -framework QtGui
-framework Carbon -framework AppKit -framework QtCore /usr/lib/libz.dylib
-framework ApplicationServices -framework AGL -framework OpenGL
Thread model: posix
-dylib_install_name
-weak_reference_mismatches non-weak -o ../../lib/libCGAL_Qt4.3.0.0.dylib
CMakeFiles/CGAL_Qt4.dir/qrc_Triangulation_2.o ../../lib/libCGAL.dylib
/opt/local/lib/libboost_thread-mt.dylib -framework QtOpenGL -framework OpenGL
-framework AGL -framework QtGui -framework Carbon -framework AppKit
-framework AGL -framework OpenGL -lstdc++ -lgcc_s.10.5 -lgcc -lSystem
../../lib/libCGAL_Qt4.3.0.0.dylib ../../lib/libCGAL_Qt4.3.dylib
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles 1 2 3 4 5
[100%] Built target CGAL_Qt4
/Users/mt/_lib_autres_que_macports/CGAL-3.4/build/CMakeFiles 0
liristvn:build mt$
begin:vcard fn:Martial TOLA n:TOLA;Martial org;quoted-printable:CNRS/INSA de Lyon/Universit=C3=A9 Claude Bernard Lyon 1/Universit=C3=A9Lu= mi=C3=A8re Lyon 2/Ecole Centrale de Lyon;Laboratoire LIRIS - UMR 5205 email;internet: title;quoted-printable:Ing=C3=A9nieur d'=C3=A9tudes CNRS url:http://liris.cnrs.fr/martial.tola version:2.1 end:vcard
- Re: [cgal-discuss] Polyhedron demo problem, (continued)
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Saboret, 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/20/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/20/2009
- [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Matthias Teich, 05/20/2009
- Re: [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Laurent Rineau (GeometryFactory), 05/20/2009
