- To:
- Subject: Re: [cgal-discuss] Polyhedron demo problem (bis)
- Date: Wed, 20 May 2009 15:38:17 +0200
Ok, with the patch it works (even if 3/4 files during patching are not modified because of errors).
So thank you again !
ps : for information, under linux and mac os x I saw that we must manually set "taucs_include_dir" in order to detect correctly taucs.
Laurent Rineau (GeometryFactory) a écrit :
On Wednesday 20 May 2009 10:35:36 Martial TOLA (CNRS-Liris) wrote:
Hello
Strange: libCGAL_Qt4.dylib is not in that list! Have you build CGAL withOf course, Qt4 is on (but Qt3 is off like under windows and linux), you can
Qt4 support?
see that in cmake-gui.txt.
Here is the logs with -v (make cgal and make Polyhedron).
Thank you for your help.
That confirms that, although CGAL_Qt4 is detected at the configuration time, libCGAL_Qt4.dylib is not linked with the executable. Add -lCGAL_Qt4 manually to CMAKE_EXE_LINKER_FLAGS.
Well,... I now remember that we (CGAL developers) have detected that CMake-2.6.3 broke the compatibility with previous versions of CMake on one detail used in CGAL scripts. We have a patch for the upcoming CGAL-3.4.1.
I have attached the patch, if you are willing to test it...
begin:vcard fn:Martial TOLA n:TOLA;Martial org;quoted-printable:CNRS/INSA de Lyon/Universit=C3=A9 Claude Bernard Lyon 1/Universit=C3=A9Lu= mi=C3=A8re Lyon 2/Ecole Centrale de Lyon;Laboratoire LIRIS - UMR 5205 email;internet: title;quoted-printable:Ing=C3=A9nieur d'=C3=A9tudes CNRS url:http://liris.cnrs.fr/martial.tola version:2.1 end:vcard
- Re: [cgal-discuss] Polyhedron demo problem (bis), (continued)
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/15/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/20/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/20/2009
- [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Matthias Teich, 05/20/2009
- Re: [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Laurent Rineau (GeometryFactory), 05/20/2009
