- To: "" <>
- Subject: RE : [cgal-discuss] Voronoi Diagram Site Deletion
- Date: Thu, 8 Oct 2009 17:47:22 -0400
- Accept-language: fr-CA, en-CA
- Acceptlanguage: fr-CA, en-CA
Hi ,
Removing a site from DT is the same as removing it from Voronoi diaram. Then
you need to use the same alorithm and refresh your Voronoi diagram.
Mir
________________________________________
De :
Date d'envoi : 8 octobre 2009 17:03
À :
Objet : [cgal-discuss] Voronoi Diagram Site Deletion
Hi,
I am pretty new to CGAL. I needed to implement Voronoi Diagrams(VD). But the
documentation of the Voronoi_diagram_2<DG,AT,AP> class does not seem to
mention a way to DELETE sites from it.
A Delaunay Graph allows Site Deletion but converting a VD to its dual and back
will make my algorithm very inefficient.
Is there something that I am overlooking ?
Thank you all.
Navneet.
- [cgal-discuss] Voronoi Diagram Site Deletion, nav17kapur, 10/08/2009
- RE : [cgal-discuss] Voronoi Diagram Site Deletion, Mir Abolfazl Mostafavi, 10/08/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Navneet Kapur, 10/09/2009
- Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Marcos R. P., 10/09/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Navneet Kapur, 10/11/2009
- Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Marcos R. P., 10/16/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, nav17kapur, 10/11/2009
- Re: [cgal-discuss] Voronoi Diagram Site Deletion, Flaminigo, 10/28/2009
