cgal-discuss - Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion
  • To:
  • Subject: Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion
  • Date: Fri, 16 Oct 2009 06:27:09 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=FJEdcNHxcqk/xZwS2s8Y6UN4tuWRhwvQgjz8+RA0U2a3zxXrFT1HlpcBDF5o737bx2ZLWHF8hQROwosrrxiuv3ztafDDI/OeQjUEYyZrYA+nSujCWpNE8Zen42ta8UonOJuq++/2f59Uj9PDSxTkhhoCU8Sm0OX1iD2ClAFJe2Y=;
Thank you, Navneet!
I really appreciated your hint.
Marcos.
De: Navneet Kapur <>
Para:
Enviadas: Dom, Outubro 11, 2009 9:06:12 AM
Assunto: Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion
Hi Marcos,
There are face_iterators to return the points at the corners of a face. You can write them into a file.
Btw, in case of such doubts, do not post in other threads.
Navneet.
On Fri, Oct 9, 2009 at 6:08 PM, Marcos R. P. <> wrote:
Hi, Friend Cgalese!
Do you know how to send the Voronoi Cell to a file?
Thank you very much!
De: Mir Abolfazl Mostafavi <>
Para: "" <>
Enviadas: Qui, Outubro 8, 2009 6:47:22 PM
Assunto: RE : [cgal-discuss] Voronoi Diagram Site Deletion
Hi ,
Removing a site from DT is the same as removing it from Voronoi diaram. Then you need to use the same alorithm and refresh your Voronoi diagram.
Mir
________________________________________
De : []
Date d'envoi : 8 octobre 2009 17:03
À :
Objet : [cgal-discuss] Voronoi Diagram Site Deletion
Hi,
I am pretty new to CGAL. I needed to implement Voronoi Diagrams(VD). But the
documentation of the Voronoi_diagram_2<DG,AT,AP>  class does not seem to
mention a way to DELETE sites from it.
A Delaunay Graph allows Site Deletion but converting a VD to its dual and back
will make my algorithm very inefficient.
Is there something that I am overlooking ?
Thank you all.
Navneet.
https://lists-sop.inria.fr/wws/info/cgal-discuss--
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
I'm NOT almost gr8.
