cgal-discuss - Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion
  • To:
  • Subject: Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion
  • Date: Sun, 11 Oct 2009 17:36:12 +0530
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=EkhchAbnERwvaePIjE7RIxax/n9Hs9bz6YAt9hSC7I3p022NmCtEWH3EaQtAGM6AoG VDQO5ZAkesMB6OeyZ6cyleZtV5g2pHHeF3/5KskbRfwVIN8IyVwwIPJrH5HOb8U/lgXf nevolKJPgba/YniTeliYdCEpJ+J3x9KmkzwBQ=
Hi Marcos,
There are face_iterators to return the points at the corners of a face. You can write them into a file.
Btw, in case of such doubts, do not post in other threads.
Navneet.
On Fri, Oct 9, 2009 at 6:08 PM, Marcos R. P. <> wrote:
Hi, Friend Cgalese!
Do you know how to send the Voronoi Cell to a file?
Thank you very much!
Marcos Rodrigues
FUNCEME - Institute for Meteorology and Water Resources of Ceará
De: Mir Abolfazl Mostafavi <>
Para: "" <>
Enviadas: Qui, Outubro 8, 2009 6:47:22 PM
Assunto: RE : [cgal-discuss] Voronoi Diagram Site Deletion
Hi ,
Removing a site from DT is the same as removing it from Voronoi diaram. Then you need to use the same alorithm and refresh your Voronoi diagram.
Mir
________________________________________
De : []
Date d'envoi : 8 octobre 2009 17:03
À :
Objet : [cgal-discuss] Voronoi Diagram Site Deletion
Hi,
I am pretty new to CGAL. I needed to implement Voronoi Diagrams(VD). But the
documentation of the Voronoi_diagram_2<DG,AT,AP>  class does not seem to
mention a way to DELETE sites from it.
A Delaunay Graph allows Site Deletion but converting a VD to its dual and back
will make my algorithm very inefficient.
Is there something that I am overlooking ?
Thank you all.
Navneet.
https://lists-sop.inria.fr/wws/info/cgal-discuss--
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
I'm NOT almost gr8.
