- To:
- Subject: Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion
- Date: Fri, 9 Oct 2009 05:38:45 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=mXm/O6PANkOIPzg8ql2y8cLF9YxsDtsjQP0hUZXFCYuX5id8kVRpBddNMlViUEdnUIWtDfaaxx4Lkp5VUwJJq3M7T2dHFWMOZpWZ0m5w1tv54GTWFPkCDTWnzX+i9eC/pftTXxXIt1zOvrXKWzp7rRurGnJAisfWhiQM8v+kjSI=;
Hi, Friend Cgalese!
Do you know how to send the Voronoi Cell to a file?
Thank you very much!
Marcos Rodrigues
FUNCEME - Institute for Meteorology and Water Resources of Ceará
De: Mir Abolfazl Mostafavi <>
Para: "" <>
Enviadas: Qui, Outubro 8, 2009 6:47:22 PM
Assunto: RE : [cgal-discuss] Voronoi Diagram Site Deletion
Hi ,
Removing a site from DT is the same as removing it from Voronoi diaram. Then you need to use the same alorithm and refresh your Voronoi diagram.
Mir
________________________________________
De : []
Date d'envoi : 8 octobre 2009 17:03
À :
Objet : [cgal-discuss] Voronoi Diagram Site Deletion
Hi,
I am pretty new to CGAL. I needed to implement Voronoi Diagrams(VD). But the
documentation of the Voronoi_diagram_2<DG,AT,AP> class does not seem to
mention a way to DELETE sites from it.
A Delaunay Graph allows Site Deletion but converting a VD to its dual and back
will make my algorithm very inefficient.
Is there something that I am overlooking ?
Thank you all.
Navneet.
https://lists-sop.inria.fr/wws/info/cgal-discuss--
Veja quais são os assuntos do momento no Yahoo! + Buscados: Top 10 - Celebridades - Música - Esportes
- [cgal-discuss] Voronoi Diagram Site Deletion, nav17kapur, 10/08/2009
- RE : [cgal-discuss] Voronoi Diagram Site Deletion, Mir Abolfazl Mostafavi, 10/08/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Navneet Kapur, 10/09/2009
- Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Marcos R. P., 10/09/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Navneet Kapur, 10/11/2009
- Res: RE : [cgal-discuss] Voronoi Diagram Site Deletion, Marcos R. P., 10/16/2009
- Re: RE : [cgal-discuss] Voronoi Diagram Site Deletion, nav17kapur, 10/11/2009
- Re: [cgal-discuss] Voronoi Diagram Site Deletion, Flaminigo, 10/28/2009
