- To:
- Subject: Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3
- Date: Sun, 15 Nov 2009 20:42:17 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=OH/SKCcB0lSFlylAoP7mAGcg0nGNoWKNckyzAOJOwtkYpf83HRLZxqce37+ZXirQrw pyf8yRMm25zojJ4OAgEvs0mX+OsU+M5QcrqWLA0Do9AVoLhY5t5MuPyi5fHKAXvgSJEX E1U5EtACm9kck+4qV9dRcjfe3t67rDjrduVIc=
Hi Josip,
The assertion says that the vertex is not contained in the Cell. When you remove vertices, cells get removed and added when re-triangulating. Internally, CGAL will reuse the memory of deleted cells for the new cells. This might be the reason you are getting the assertion.
-- Nico
On Sun, Nov 15, 2009 at 6:26 PM, Josip Dzolonga <> wrote:
Hello everyone,
I am trying to remove some certain points from the Delaunay triangulation. I had some problems even before, and got some advice from here, but the problem still pertains. The problematic code follows
for(Finite_vertices_iterator vit = T.finite_vertices_begin();
vit != T.finite_vertices_end(); ++vit) {
if(seen.find(vit->point()) != seen.end()) {
seen.erase(vit->point());
T.remove(vit);
Where seen is of type std::set<Point> and has been already filled. Later on when I try to use the triangulation, I get the following error
CGAL error: assertion violation!
Expr: v == V[3]
File: /usr/include/CGAL/Triangulation_ds_cell_base_3.h
Line: 98
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct NULL not valid
Aborted
Which comes from the function int index(const Vertex_handle& v). I can not remove the same vertex twice, since I am iterating over the finite vertices and this is the only place where vertex removal is taking place. Any ideas would be highly appreciated!
Best,
Josip
- [cgal-discuss] Problems with removing points from a triangulation,Take 3, Josip Dzolonga, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Nico Kruithof, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Josip Dzolonga, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Andreas Fabri, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Sylvain Pion, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Josip Dzolonga, 11/19/2009
