cgal-discuss - Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3
  • To:
  • Subject: Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3
  • Date: Sun, 15 Nov 2009 20:56:39 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=TQJck8BKnIeY70jQM2KerrV3HQKhdjbY7+CABoiHDpsgEPGWHJTxzL1Zjp9dmTbGI+ iWW4S4VUR7d5lJS2OHXBh+jOxPtp6dZXtYSbn/H6WT2wSCMhBWPsdDZ00xknOkWNyqp+ LWlFWmsDffiA9OhI1vyg6tN8hJr/2Jz/1ps9Q=
Hi Nico,
I thought of that, but at no point I am reusing old cell handles/vertex handles. I thought that while removing them, I might be causing the problem - but even if I change to code to the following, the problems remains
while(!seen.empty()) {
          for(Finite_vertices_iterator vit = T.finite_vertices_begin();
                vit != T.finite_vertices_end(); ++vit) {
                if(seen.find(vit->point()) != seen.end()) {
                    seen.erase(vit->point());
                    T.remove(vit);
                    break;
That is, I am iterating again over all vertices.
Thanks,
Josip
On Sun, Nov 15, 2009 at 8:42 PM, Nico Kruithof <> wrote:
Hi Josip,
The assertion says that the vertex is not contained in the Cell. When you remove vertices, cells get removed and added when re-triangulating. Internally, CGAL will reuse the memory of deleted cells for the new cells. This might be the reason you are getting the assertion.
-- Nico
On Sun, Nov 15, 2009 at 6:26 PM, Josip Dzolonga <> wrote:
Hello everyone,
I am trying to remove some certain points from the Delaunay triangulation. I had some problems even before, and got some advice from here, but the problem still pertains. The problematic code follows
                T.remove(vit);
Where seen is of type std::set<Point> and has been already filled. Later on when I try to use the triangulation, I get the following error
CGAL error: assertion violation!
Expr: v == V[3]
File: /usr/include/CGAL/Triangulation_ds_cell_base_3.h
Line: 98
terminate called after throwing an instance of 'std::logic_error'
  what():  basic_string::_S_construct NULL not valid
Aborted
Which comes from the function  int index(const Vertex_handle& v). I can not remove the same vertex twice, since I am iterating over the finite vertices and this is the only place where vertex removal is taking place. Any ideas would be highly appreciated!
Best,
Josip
