- To:
- Subject: Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3
- Date: Sun, 15 Nov 2009 22:11:41 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=X58Cuwwcg9AP5KcHEtqC3Wb6o/1mGh9S3Ykxo4lgErNkWJ3RfB7H5F568e0MBBgtii atShxpMkv1TTM+on673tQM6XwXpr7EJK2Ld5Ju/zdphSsdwePnZt499H5VgGN7SAWSC+ XnttrpG5VEBm9wpv9cQIyS3cjwcx4EzAZa5ug=
I was referring to this
while(!seen.empty()) {
for(Finite_vertices_iterator vit = T.finite_vertices_begin();
vit != T.finite_vertices_end(); ++vit) {
if(seen.find(vit->point()) != seen.end()) {
seen.erase(vit->point());
T.remove(vit);
break;vit != T.finite_vertices_end(); ++vit) {
T.remove(vit);
I break the loop after a point is removed. I also tried the code that you provided, but that unfortunately did not solve the problem.
Best,
Josip
On Sun, Nov 15, 2009 at 10:08 PM, Andreas Fabri <> wrote:
Hi Josip,
I am not sure you understood my explanantion, but it can also be
that I didn't understand yours.
It is a mistake to do the ++vit, AFTER having called T.remove(vit),
and that is what your for loop does.
My version makes a copy of thr iterator, advances the iterator
and only then removes the vertex.
andreas
Josip Dzolonga wrote:
Hi Andreas,
I corrected myself in my latest reply, but that did not solve the problem.
Josip
<mailto: <mailto:>>>On Sun, Nov 15, 2009 at 9:07 PM, Andreas Fabri < <mailto:>> wrote:
Hi Josip,
You shouldn't expect that ++vit works correctly after that you called
T.remove(vit).
You better write this
vit != T.finite_vertices_end();) {
Vertex_handle vh = vit;
++vit;
T.remove(vh);
break;
Note that the same would be true for a std::list.
andreas
Hi Nico,
I thought of that, but at no point I am reusing old cell
handles/vertex handles. I thought that while removing them, I
might be causing the problem - but even if I change to code to
the following, the problems remains
T.remove(vit);
break;
That is, I am iterating again over all vertices.
Thanks,
Josip
On Sun, Nov 15, 2009 at 8:42 PM, Nico Kruithof
< <mailto:>
wrote:
Hi Josip,
The assertion says that the vertex is not contained in the Cell.
When you remove vertices, cells get removed and added when
re-triangulating. Internally, CGAL will reuse the memory of
deleted
cells for the new cells. This might be the reason you are getting
the assertion.
-- Nico
On Sun, Nov 15, 2009 at 6:26 PM, Josip Dzolonga
< <mailto:><mailto: <mailto:>>> wrote:
Hello everyone,
I am trying to remove some certain points from the Delaunay
triangulation. I had some problems even before, and got some
advice from here, but the problem still pertains. The
problematic code follows
T.remove(vit);
Where seen is of type std::set<Point> and has been already
filled. Later on when I try to use the triangulation, I
get the
following error
CGAL error: assertion violation!
Expr: v == V[3]
File: /usr/include/CGAL/Triangulation_ds_cell_base_3.h
Line: 98
terminate called after throwing an instance of
'std::logic_error'
what(): basic_string::_S_construct NULL not valid
Aborted
Which comes from the function int index(const Vertex_handle&
v). I can not remove the same vertex twice, since I am
iterating
over the finite vertices and this is the only place where
vertex
removal is taking place. Any ideas would be highly
appreciated!
Best,
Josip
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Problems with removing points from a triangulation,Take 3, Josip Dzolonga, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Nico Kruithof, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Josip Dzolonga, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Andreas Fabri, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Sylvain Pion, 11/15/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Josip Dzolonga, 11/19/2009
- Re: [cgal-discuss] Problems with removing points from a triangulation,Take 3, Manuel Caroli, 11/19/2009
