cgal-discuss - Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3
  • To:
  • Subject: Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3
  • Date: Fri, 20 Nov 2009 14:59:20 +0100
Ramin H wrote:
Thank you for responding. It's ok if the boundary is approximated but
it looks like the algorithm does not finish it's job. I run the Mesh_3
example with no changes to size and approximation factors.
I am attaching the screen shot of the out.mesh, visualized by medit.
Also, here is the .off file that defines the cube:
========= Begin of OFF file ========
OFF
8 6 0
1.632993 0.000000 1.154701
0.000000 1.632993 1.154701
-1.632993 0.000000 1.154701
0.000000 -1.632993 1.154701
1.632993 0.000000 -1.154701
0.000000 1.632993 -1.154701
-1.632993 0.000000 -1.154701
0.000000 -1.632993 -1.154701
4 0 1 2 3
4 7 4 0 3
4 4 5 1 0
4 5 6 2 1
4 3 2 6 7
4 6 5 4 7
========= End of OFF file ========
Thanks,
-Ramin
On Fri, Nov 20, 2009 at 3:49 AM, Stephane Tayeb
wrote:
Hi,
Ramin H wrote:
Hi everyone,
Before I use the 3D mesh generation functionality of CGAL 3.5 over a
complicated domain, I decided to use a cube as input to Mesh_3
example. The mesh created in out.mesh is missing parts of the surface
boundary of the cube.
What do you mean by missing parts please ?
Is it possible to mesh cubes with the 3D mesh generation functionality
or they fall under "domains with sharp edges" category?
Yes it is a domain with sharp edges if you want the have the edges in the
mesh. The actual implementation is designed for smooth surfaces only.
If you try to mesh a cube, you will only have an approximation of the edges
(the element size near the edges depends of the surface approximation error
criterion).
Any idea how one can possibly overcome this issue?
Thank you,
-Ramin
Mesh_3 polyhedral domain is designed to handle triangulated surfaces. In your case, you use a quadrangular definition of the surface in the off file. That's why you have holes in the mesh.
Please try the attached file instead of yours.
Best,
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
OFF
8 12 0
3 0 1 2
3 0 2 3
3 7 4 0
3 7 0 3
3 4 5 1
3 4 1 0
3 5 6 2
3 5 2 1
3 3 2 6
3 3 6 7
3 6 5 4
3 6 4 7
