- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3
- Date: Fri, 20 Nov 2009 16:16:22 +0100
Ramin H wrote:
Thank you :) That solved the problem.
One more question: Does the direction of the normal vector for each
triangle that defines the domain matter? In other words, does the
order of vertices that define a triangle matter?
-Ramin
Yes. The surface should be well-oriented. If it is not, the creation of the Polyhedron object from the off file will fail. You could have a look at http://www.cgal.org/Manual/last/doc_html/cgal_manual/Polyhedron/Chapter_main.html
if you need further informations.
Best,
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Ramin H, 11/18/2009
- Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Stephane Tayeb, 11/20/2009
- Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Ramin H, 11/20/2009
