cgal-discuss - Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3
  • To:
  • Subject: Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3
  • Date: Fri, 20 Nov 2009 09:49:46 +0100
Hi,
Ramin H wrote:
Hi everyone,
Before I use the 3D mesh generation functionality of CGAL 3.5 over a
complicated domain, I decided to use a cube as input to Mesh_3
example. The mesh created in out.mesh is missing parts of the surface
boundary of the cube.
What do you mean by missing parts please ?
Is it possible to mesh cubes with the 3D mesh generation functionality
or they fall under "domains with sharp edges" category?
Yes it is a domain with sharp edges if you want the have the edges in the mesh. The actual implementation is designed for smooth surfaces only.
If you try to mesh a cube, you will only have an approximation of the edges (the element size near the edges depends of the surface approximation error criterion).
Any idea how one can possibly overcome this issue?
Thank you,
-Ramin
Best,
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
