- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3
- Date: Fri, 20 Nov 2009 09:51:20 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=JtHCtJxCdx82ZZ37Ju4wzBWdZCqe4AtQxMllBmSgZbYlWOV03zkRXcXeWyUlQR5kgb shiVuexHnnBD39lDGWQJIu7CSwKzkJlYYT/i6HV+7azgdTg4ymN7MeMcRa+vARm5MhH3 auuGcVRj3qjT7qwVw3msr2MNFYNikgE3PyKl4=
Thank you :) That solved the problem.
One more question: Does the direction of the normal vector for each
triangle that defines the domain matter? In other words, does the
order of vertices that define a triangle matter?
-Ramin
On Fri, Nov 20, 2009 at 8:59 AM, Stephane Tayeb
wrote:
> Ramin H wrote:
>> Thank you for responding. It's ok if the boundary is approximated but
>> it looks like the algorithm does not finish it's job. I run the Mesh_3
>> example with no changes to size and approximation factors.
>> I am attaching the screen shot of the out.mesh, visualized by medit.
>> Also, here is the .off file that defines the cube:
>> ========= Begin of OFF file ========
>> OFF
>> 8 6 0
>> 1.632993 0.000000 1.154701
>> 0.000000 1.632993 1.154701
>> -1.632993 0.000000 1.154701
>> 0.000000 -1.632993 1.154701
>> 1.632993 0.000000 -1.154701
>> 0.000000 1.632993 -1.154701
>> -1.632993 0.000000 -1.154701
>> 0.000000 -1.632993 -1.154701
>> 4 0 1 2 3
>> 4 7 4 0 3
>> 4 4 5 1 0
>> 4 5 6 2 1
>> 4 3 2 6 7
>> 4 6 5 4 7
>> ========= End of OFF file ========
>> Thanks,
>> -Ramin
>> On Fri, Nov 20, 2009 at 3:49 AM, Stephane Tayeb
>> wrote:
>>> Hi,
>>> Ramin H wrote:
>>>> Hi everyone,
>>>> Before I use the 3D mesh generation functionality of CGAL 3.5 over a
>>>> complicated domain, I decided to use a cube as input to Mesh_3
>>>> example. The mesh created in out.mesh is missing parts of the surface
>>>> boundary of the cube.
>>> What do you mean by missing parts please ?
>>>> Is it possible to mesh cubes with the 3D mesh generation functionality
>>>> or they fall under "domains with sharp edges" category?
>>> Yes it is a domain with sharp edges if you want the have the edges in the
>>> mesh. The actual implementation is designed for smooth surfaces only.
>>> If you try to mesh a cube, you will only have an approximation of the
>>> edges
>>> (the element size near the edges depends of the surface approximation
>>> error
>>> criterion).
>>>> Any idea how one can possibly overcome this issue?
>>>> Thank you,
>>>> -Ramin
> Mesh_3 polyhedral domain is designed to handle triangulated surfaces. In
> your case, you use a quadrangular definition of the surface in the off file.
> That's why you have holes in the mesh.
> Please try the attached file instead of yours.
> Best,
> Stephane Tayeb
> Software engineer - INRIA Sophia Antipolis
> Geometrica Project-Team
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> OFF
> 8 12 0
> 3 0 1 2
> 3 0 2 3
> 3 7 4 0
> 3 7 0 3
> 3 4 5 1
> 3 4 1 0
> 3 5 6 2
> 3 5 2 1
> 3 3 2 6
> 3 3 6 7
> 3 6 5 4
> 3 6 4 7
- [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Ramin H, 11/18/2009
- Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Stephane Tayeb, 11/20/2009
- Re: [cgal-discuss] 3D Mesh Generation - mesh a cube with Mesh_3, Ramin H, 11/20/2009
