cgal-discuss - Re: [cgal-discuss] linker error in cgal example
  • To:
  • Subject: Re: [cgal-discuss] linker error in cgal example
  • Date: Thu, 10 Dec 2009 18:57:42 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=BX9YSwRc2b9FuqhBViEUx0FXNu32tGLpmeDkBc5gjTLreN+9HH+fFnxvyJNpDUj/G5 mTB9m29jBMh8H6XPDDeprzhpYwnDTQyDeV7nYM0Y1jrCT+tFjhYZv5QdV14LGQuph3+7 wKulIsvPfrlYRDUI3QxLfYxYOfu+zk1uhhu5Q=
Hi Laurent,
Thanks for the reply. I am using Microsoft Visual Studio 2008 version 9 and windows XP 64 . I am not sure that include service pack. I just installed it from CD.
I recompile it with the CGAL_LIB_DIAGNOSTIC and attached the log to this e-mail.
Thank you,
Tina
On Thu, Dec 10, 2009 at 6:11 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le jeudi 10 décembre 2009 19:00:53, tina rumi a écrit :
> Hi Laurent,
> Thank you for your reply. I tried with the cmake too but still same errors.
> I even addressed all the lib files in my code individually and still have
> same error. I am guessing the problem is not finding library. maybe I am
> missing some of  the lib file.  I have following files :
> "C:\CGAL\CGAL-3.5\auxiliary\gmp\lib" :
> gmp-vc90-mt.lib
> gmp-vc90-mt-gd.lib
> gmp-vc90-mt-s.lib
> gmp-vc90-mt-sgd.lib
> mpfr-vc90-mt.lib
> mpfr-vc90-mt-gd.lib
> mpfr-vc90-mt-s.lib
> mpfr-vc90-mt-sgd.lib
> gmp-vc90-mt.dll
> gmp-vc90-mt-gd.dll
> mpfr-vc90-mt.dll
> mpfr-vc90-mt-gd.dll
> and in "C:\CGAL\CGAL-3.5\auxiliary\gmp\include" :
> gmp.h
> mpfr.h
> Is there any file missing? I really appreciate your help, I don't know what
> else should I do.
There is something strange. We need more information to understand. What
version of the MSVS C++ Compiler do you use? Have you installed MSVS service
packs?
Can you retry to compile the same program with the cpp macro
CGAL_LIB_DIAGNOSTIC defined, and give use the full compilation log (that should
then display the list of auto-linked CGAL libraries).
Same question for Pierre, who also seems to have problems with Visual and GMP.
Laurent Rineau, PhD
Release Manager of the CGAL Project       http://www.cgal.org/
R&D
Engineer at GeometryFactory           http://www.geometryfactory.com/
Build Log
Rebuild started: Project: cloud_points, Configuration: Debug|Win32
Command Lines
Creating temporary file "f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000511723792.rsp" with contents
/Od /I "C:\Program Files (x86)\boost\boost_1_40" /I "C:\CGAL\CGAL-3.5\include" /I "C:\CGAL\CGAL-3.5\auxiliary\gmp\include" /I "C:\Qt\2009.04\qt\include\QtCore" /I "C:\Qt\2009.04\qt\include\QtGui" /I "C:\Qt\2009.04\qt\include" /I "C:\Qt\2009.04\qt\include\ActiveQt" /I "debug" /I "." /I "C:\Qt\2009.04\qt\mkspecs\win32-msvc2005" /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNICODE" /D "_AFXDLL" /Gm /EHsc /RTC1 /MD /Yu"stdafx.h" /Fp"Debug\cloud_points.pch" /Fo"Debug\\" /Fd"Debug\vc90.pdb" /W3 /c /ZI /TP .\cloud_points.cpp
Creating command line "cl.exe @f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000511723792.rsp /nologo /errorReport:prompt"
Creating temporary file "f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000611723792.rsp" with contents
/Od /I "C:\Program Files (x86)\boost\boost_1_40" /I "C:\CGAL\CGAL-3.5\include" /I "C:\CGAL\CGAL-3.5\auxiliary\gmp\include" /I "C:\Qt\2009.04\qt\include\QtCore" /I "C:\Qt\2009.04\qt\include\QtGui" /I "C:\Qt\2009.04\qt\include" /I "C:\Qt\2009.04\qt\include\ActiveQt" /I "debug" /I "." /I "C:\Qt\2009.04\qt\mkspecs\win32-msvc2005" /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNICODE" /D "_AFXDLL" /Gm /EHsc /RTC1 /MD /Yc"stdafx.h" /Fp"Debug\cloud_points.pch" /Fo"Debug\\" /Fd"Debug\vc90.pdb" /W3 /c /ZI /TP .\stdafx.cpp
Creating command line "cl.exe @f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000611723792.rsp /nologo /errorReport:prompt"
Creating temporary file "f:\fingerprint\codes\cloud_points\cloud_points\Debug\TMP00000711723792.tmp" with contents
1 /* CREATEPROCESS_MANIFEST_RESOURCE_ID */ 24 /* RT_MANIFEST */ ".\\Debug\\cloud_points.exe.embed.manifest"
Creating command line "rc.exe /fo".\Debug\cloud_points.exe.embed.manifest.res" f:\fingerprint\codes\cloud_points\cloud_points\Debug\TMP00000711723792.tmp"
Creating temporary file "f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000811723792.rsp" with contents
/OUT:"F:\fingerprint\codes\cloud_points\Debug\cloud_points.exe" /INCREMENTAL /MANIFEST /MANIFESTFILE:"Debug\cloud_points.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"F:\fingerprint\codes\cloud_points\Debug\cloud_points.pdb" /SUBSYSTEM:CONSOLE /DYNAMICBASE /NXCOMPAT /MACHINE:X86 C:\Qt\2009.04\qt\lib\qtmaind.lib C:\Qt\2009.04\qt\lib\QtGuid4.lib C:\Qt\2009.04\qt\lib\QtCored4.lib psapi.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc90-mt.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc90-mt-gd.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc90-mt-s.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\gmp-vc90-mt-sgd.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\mpfr-vc90-mt.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\mpfr-vc90-mt-gd.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\mpfr-vc90-mt-s.lib C:\CGAL\CGAL-3.5\auxiliary\gmp\lib\mpfr-vc90-mt-sgd.lib
".\Debug\cloud_points.obj"
".\Debug\stdafx.obj"
Creating command line "link.exe @f:\fingerprint\codes\cloud_points\cloud_points\Debug\RSP00000811723792.rsp /NOLOGO /ERRORREPORT:PROMPT"
Output Window
Compiling...
stdafx.cpp
Compiling...
cloud_points.cpp
Linking to lib file: CGAL-vc90-mt-gd.lib
Linking to lib file: gmp-vc90-mt-gd.lib
Linking to lib file: mpfr-vc90-mt-gd.lib
Linking to lib file: libtaucs-vc90-mt-gd.lib
Linking to lib file: libmetis-vc90-mt-gd.lib
Linking to lib file: liblapack.lib
Linking to lib file: libf77blas.lib
Linking to lib file: libcblas.lib
Linking to lib file: libatlas.lib
Linking to lib file: vcf2c-vc90-mt-gd.lib
c:\cgal\cgal-3.5\include\cgal\win32_exception.h(77) : warning C4535: calling _set_se_translator() requires /EHa
c:\cgal\cgal-3.5\include\cgal\taucs_solver.h(227) : warning C4996: 'tempnam': The POSIX name for this item is deprecated. Instead, use the ISO C++ conformant name: _tempnam. See online help for details.
        c:\program files (x86)\microsoft visual studio 9.0\vc\include\stdio.h(713) : see declaration of 'tempnam'
        c:\cgal\cgal-3.5\include\cgal\taucs_solver.h(190) : while compiling class template member function 'bool CGAL::Taucs_solver::factorize_ooc(void)'
        with
            T=double
        c:\cgal\cgal-3.5\include\cgal\poisson_reconstruction_function.h(325) : see reference to class template instantiation 'CGAL::Taucs_solver' being compiled
        with
            T=double
        c:\cgal\cgal-3.5\include\cgal\poisson_reconstruction_function.h(300) : while compiling class template member function 'bool CGAL::Poisson_reconstruction_function::solve_poisson(double)'
        with
            Gt=Kernel
        f:\fingerprint\codes\cloud_points\cloud_points\cloud_points.cpp(209) : see reference to class template instantiation 'CGAL::Poisson_reconstruction_function' being compiled
        with
            Gt=Kernel
c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(119) : warning C4996: 'std::copy': Function call with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
        c:\program files (x86)\microsoft visual studio 9.0\vc\include\xutility(2550) : see declaration of 'std::copy'
        c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(115) : while compiling class template member function 'CGAL::Kd_tree_rectangle::Kd_tree_rectangle(const CGAL::Kd_tree_rectangle &)'
        with
            SearchTraits=Tree_traits
        c:\cgal\cgal-3.5\include\cgal\kd_tree.h(254) : see reference to class template instantiation 'CGAL::Kd_tree_rectangle' being compiled
        with
        c:\cgal\cgal-3.5\include\cgal\kd_tree.h(252) : while compiling class template member function 'CGAL::Kd_tree::~Kd_tree(void)'
        with
            SearchTraits=Tree_traits,
            Splitter_=CGAL::Sliding_midpoint,
            UseExtendedNode=CGAL::Tag_true
        c:\cgal\cgal-3.5\include\cgal\orthogonal_k_neighbor_search.h(52) : see reference to class template instantiation 'CGAL::Kd_tree' being compiled
        with
        c:\cgal\cgal-3.5\include\cgal\compute_average_spacing.h(129) : see reference to class template instantiation 'CGAL::Orthogonal_k_neighbor_search' being compiled
        with
        c:\cgal\cgal-3.5\include\cgal\compute_average_spacing.h(183) : see reference to function template instantiation 'double CGAL::compute_average_spacing>(InputIterator,InputIterator,PointPMap,unsigned int,const Kernel &)' being compiled
        with
            InputIterator=std::_Vector_iterator>,
            PointPMap=CGAL::Dereference_property_map>,
            CK=CGAL::Simple_cartesian,
            Kernel=CGAL::Filtered_kernel>
        c:\cgal\cgal-3.5\include\cgal\compute_average_spacing.h(199) : see reference to function template instantiation 'double CGAL::compute_average_spacing>(InputIterator,InputIterator,PointPMap,unsigned int)' being compiled
        with
            T=CGAL::Point_with_normal_3,
        f:\fingerprint\codes\cloud_points\cloud_points\cloud_points.cpp(218) : see reference to function template instantiation 'double CGAL::compute_average_spacing>(InputIterator,InputIterator,unsigned int)' being compiled
        with
            _Ty=Point_with_normal,
            _Alloc=std::allocator,
c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(120) : warning C4996: 'std::copy': Function call with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d\min_sphere_of_spheres_d_pair.h(112) : warning C4244: '=' : conversion from 'double' to 'float', possible loss of data
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d\min_sphere_of_spheres_d_impl.h(178) : see reference to function template instantiation 'T CGAL::inner_product_n<3,float,const double*,const double*,std::plus<_Ty>,CGAL::Min_sphere_of_spheres_d_impl::Subtract_and_square>(InputIterator1,InputIterator2,T,BinaryOperation1,BinaryOperation2)' being compiled
        with
            T=float,
            _Ty=double,
            FT=double,
            InputIterator1=const double *,
            InputIterator2=const double *,
            BinaryOperation1=std::plus,
            BinaryOperation2=CGAL::Min_sphere_of_spheres_d_impl::Subtract_and_square
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d\min_sphere_of_spheres_d_impl.h(164) : while compiling class template member function 'bool CGAL::Min_sphere_of_spheres_d::find_farthest(int,int,int &,CGAL::Tag_false,CGAL::Tag_false)'
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d.h(183) : while compiling class template member function 'void CGAL::Min_sphere_of_spheres_d::prepare(int)'
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d.h(206) : while compiling class template member function 'bool CGAL::Min_sphere_of_spheres_d::is_empty(void)'
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\min_sphere_of_spheres_d.h(214) : while compiling class template member function 'const double &CGAL::Min_sphere_of_spheres_d::radius(void)'
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\reconstruction_triangulation_3.h(348) : see reference to class template instantiation 'CGAL::Min_sphere_of_spheres_d' being compiled
        with
            Traits=Traits
        c:\cgal\cgal-3.5\include\cgal\reconstruction_triangulation_3.h(337) : while compiling class template member function 'CGAL::Sphere_3 CGAL::Reconstruction_triangulation_3::input_points_bounding_sphere(void) const'
        with
            R_=CGAL::Filtered_kernel>,
            BaseGt=CGAL::Robust_circumcenter_filtered_traits_3
        c:\cgal\cgal-3.5\include\cgal\poisson_reconstruction_function.h(82) : see reference to class template instantiation 'CGAL::Reconstruction_triangulation_3' being compiled
        with
c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(245) : warning C4996: 'std::copy': Function call with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
        c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(242) : while compiling class template member function 'CGAL::Kd_tree_rectangle &CGAL::Kd_tree_rectangle::operator =(const CGAL::Kd_tree_rectangle &)'
        with
c:\cgal\cgal-3.5\include\cgal\kd_tree_rectangle.h(246) : warning C4996: 'std::copy': Function call with parameters that may be unsafe - this call relies on the caller to check that the passed values are correct. To disable this warning, use -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++ 'Checked Iterators'
Compiling manifest to resources...
Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0
Copyright (C) Microsoft Corporation.  All rights reserved.
Linking...
LINK : warning LNK4098: defaultlib 'MSVCRTD' conflicts with use of other libs; use /NODEFAULTLIB:library
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_clear referenced in function "public: __thiscall CGAL::Gmpq_rep::~Gmpq_rep(void)" (??1Gmpq_rep@CGAL@@QAE@XZ)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_set_d referenced in function "public: __thiscall CGAL::Gmpq::Gmpq(double)" (??0Gmpq@CGAL@@QAE@N@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_init referenced in function "public: __thiscall CGAL::Gmpq_rep::Gmpq_rep(void)" (??0Gmpq_rep@CGAL@@QAE@XZ)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_mul referenced in function "public: class CGAL::Gmpq & __thiscall CGAL::Gmpq::operator*=(class CGAL::Gmpq const &)" (??XGmpq@CGAL@@QAEAAV01@ABV01@@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_cmp_si referenced in function "bool __cdecl CGAL::operator==(class CGAL::Gmpq const &,int)" (??8CGAL@@YA_NABVGmpq@0@H@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp__mpfr_clear referenced in function "public: struct std::pair __thiscall CGAL::Real_embeddable_traits::To_interval::operator()(class CGAL::Gmpq const &)const " (??RTo_interval@?$Real_embeddable_traits@VGmpq@CGAL@@@CGAL@@QBE?AU?$pair@NN@std@@ABVGmpq@2@@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp__mpfr_get_d referenced in function "public: struct std::pair __thiscall CGAL::Real_embeddable_traits::To_interval::operator()(class CGAL::Gmpq const &)const " (??RTo_interval@?$Real_embeddable_traits@VGmpq@CGAL@@@CGAL@@QBE?AU?$pair@NN@std@@ABVGmpq@2@@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp__mpfr_set_q referenced in function "public: struct std::pair __thiscall CGAL::Real_embeddable_traits::To_interval::operator()(class CGAL::Gmpq const &)const " (??RTo_interval@?$Real_embeddable_traits@VGmpq@CGAL@@@CGAL@@QBE?AU?$pair@NN@std@@ABVGmpq@2@@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp__mpfr_init2 referenced in function "public: struct std::pair __thiscall CGAL::Real_embeddable_traits::To_interval::operator()(class CGAL::Gmpq const &)const " (??RTo_interval@?$Real_embeddable_traits@VGmpq@CGAL@@@CGAL@@QBE?AU?$pair@NN@std@@ABVGmpq@2@@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_add referenced in function "public: class CGAL::Gmpq & __thiscall CGAL::Gmpq::operator+=(class CGAL::Gmpq const &)" (??YGmpq@CGAL@@QAEAAV01@ABV01@@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_sub referenced in function "public: class CGAL::Gmpq & __thiscall CGAL::Gmpq::operator-=(class CGAL::Gmpq const &)" (??ZGmpq@CGAL@@QAEAAV01@ABV01@@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_set_si referenced in function "public: __thiscall CGAL::Gmpq::Gmpq(int)" (??0Gmpq@CGAL@@QAE@H@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_div referenced in function "public: class CGAL::Gmpq & __thiscall CGAL::Gmpq::operator/=(class CGAL::Gmpq const &)" (??_0Gmpq@CGAL@@QAEAAV01@ABV01@@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_cmp referenced in function "bool __cdecl CGAL::operator<(class CGAL::Gmpq const &,class CGAL::Gmpq const &)" (??MCGAL@@YA_NABVGmpq@0@0@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_equal referenced in function "bool __cdecl CGAL::operator==(class CGAL::Gmpq const &,class CGAL::Gmpq const &)" (??8CGAL@@YA_NABVGmpq@0@0@Z)
cloud_points.obj : error LNK2019: unresolved external symbol __imp____gmpq_set referenced in function ___gmpq_neg
F:\fingerprint\codes\cloud_points\Debug\cloud_points.exe : fatal error LNK1120: 16 unresolved externals
Results
Build log was saved at "file://f:\fingerprint\codes\cloud_points\cloud_points\Debug\BuildLog.htm"
cloud_points - 17 error(s), 8 warning(s)
