- To: <>
- Subject: RE: [cgal-discuss] cmake does not identify boost
- Date: Tue, 2 Feb 2010 14:43:20 +0200
Oh thanks, I didn't do bjam install (didn't see it in any documentation?)
the boost documentation is very frustrating; I am trying to install it
manually, since I want to work 64-bit, and BoostPro only installs 32-bit
precompiled binaries. If anyone has complete instructions on how to setup
CGAL, beginning from boost and on to work with 64-bit, I'd be very grateful.
Amir.
-----Original Message-----
[mailto:]
Sent: Tuesday, February 02, 2010 2:41 PM
To:
Subject: Re: [cgal-discuss] cmake does not identify boost
On Tuesday 02 February 2010 13:02:48 Amir Vaxman wrote:
> Hello,
> I tried to compile CGAL 3.5.1 with cmake (2.6.3) after having installed
and
> compiled boost 1.41.1. I noticed that the lib libraries directory
structure
> in 1.41.1 does not match the one in 1.38.1, and therefore, cmake is not
> able to find it. I am not proficient with the cmake script, so I don't
> really know how to direct it to find the compiled boost libraries. Does
> CGAL support only the versions of boost that create the directory
> structure BOOSTROOT\lib? (instead of the new \BOOSTROOT\bin.v2.)
I am not sure. The FindBoost.cmake shipped within CGAL most mostly from
CMake
(CGAL developers have tweaked it a bit, though). If I correclty read the
macro, the CMake macro FindBoost only search for *installed* Boost. Once you
have Boost compiled, you need to install it (use "bjam install"), so that
its
layout is correctly detected by the CMake macro.
Laurent Rineau, PhD
- [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/02/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Yang Liu, 02/02/2010
