- To: <>
- Subject: RE: [cgal-discuss] cmake does not identify boost
- Date: Tue, 2 Feb 2010 17:02:03 +0200
The plain "cmake-gui ." within this shell, which has all of these
environment variables. Also, upon configurations, all the cmake CGAL_XYZ
tests produce "Failed", whatever that means.
-----Original Message-----
[mailto:]
Sent: Tuesday, February 02, 2010 4:58 PM
To:
Subject: Re: [cgal-discuss] cmake does not identify boost
On Tuesday 02 February 2010 15:32:27 Amir Vaxman wrote:
> What should these values contain?
> I have:
> %lib% - c:\Program Files (x86)\Microsoft Visual Studio
> 9.0\VC\ATLMFC\LIB\amd64;c:\Progra
> m Files (x86)\Microsoft Visual Studio 9.0\VC\LIB\amd64;C:\Program
> Files\\Microso
> ft SDKs\Windows\v6.0A\lib\x64;
> %include% - c:\Program Files (x86)\Microsoft Visual Studio
> 9.0\VC\ATLMFC\INCLUDE;c:\Program
> Files (x86)\Microsoft Visual Studio 9.0\VC\INCLUDE;C:\Program
> Files\\Microsoft S
> DKs\Windows\v6.0A\include;
> Nothing like %headers%
On my machine, which is only 32 bits, I have:
INCLUDE='C:\Program Files (x86)\Microsoft Visual Studio
9.0\VC\INCLUDE;C:\Program Files\Microsoft SDKs\Windows\v6.0A\include;'
LIB='C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\LIB;C:\Program
Files\Microsoft SDKs\Windows\v6.0A\lib;'
LIBPATH='C:\Windows\Microsoft.NET\Framework\v3.5;C:\Windows\Microsoft.NET\Fr
amework\v2.0.50727;C:\Program Files (x86)\Microsoft Visual Studio
9.0\VC\LIB;'
VCINSTALLDIR='C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC'
Your variables seems right. But maybe other users, using 64 bits MSVS, could
confirm.
What version of CMake do you use? Is that the plain cmake-gui.exe, or one
you get from Cygwin?
Are you sure you cmake-gui is running in a shell having all those variables?
Laurent Rineau, PhD
- [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/02/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Yang Liu, 02/02/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/03/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/03/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/10/2010
- Re: [cgal-discuss] cmake does not identify boost, Yang Liu, 02/10/2010
- [cgal-discuss] Pb with mesh_3D_image example, Sylvain Gouttebroze, 02/10/2010
