cgal-discuss - RE: [cgal-discuss] cmake does not identify boost
  • To: <>
  • Subject: RE: [cgal-discuss] cmake does not identify boost
  • Date: Tue, 2 Feb 2010 15:35:16 +0200
Actually, I am now getting the " This compiler does not have a working STL"
error (I am trying to work with vc9.0 64-bit). I saw that it appeared on the
list once, and there was something mentioned about %HEADERS% and %LIBS%? I
couldn't find what is it about. Are these variables in cmake? Environment
variables that point to STL in some manner?
-----Original Message-----
[mailto:]
Sent: Tuesday, February 02, 2010 3:13 PM
To:
Cc: Yang Liu
Subject: Re: [cgal-discuss] cmake does not identify boost
On Tuesday 02 February 2010 14:03:33 Yang Liu wrote:
> Hi, Amir,
> We have a project based on CGAL, the following detailed CGAL-install
> instruction is good for you.
:-) The world is small. That is the content of:
http://alice.loria.fr/WIKI/index.php/Graphite/CGAL
Yang, are you working on Alice? I would like to discuss about the way you
have
setup your Mediawiki installation. (Maybe reply in private to avoid
spamming
the list with a private discussion.)
Laurent Rineau, PhD
