- To:
- Cc: Yang Liu <>
- Subject: Re: [cgal-discuss] cmake does not identify boost
- Date: Tue, 2 Feb 2010 14:13:11 +0100
On Tuesday 02 February 2010 14:03:33 Yang Liu wrote:
> Hi, Amir,
> We have a project based on CGAL, the following detailed CGAL-install
> instruction is good for you.
:-) The world is small. That is the content of:
http://alice.loria.fr/WIKI/index.php/Graphite/CGAL
Yang, are you working on Alice? I would like to discuss about the way you
have
setup your Mediawiki installation. (Maybe reply in private to avoid spamming
the list with a private discussion.)
Laurent Rineau, PhD
- [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/02/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Yang Liu, 02/02/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/03/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/03/2010
