- To:
- Subject: Re: [cgal-discuss] cmake does not identify boost
- Date: Tue, 2 Feb 2010 17:24:34 +0100
Le mardi 02 février 2010 16:17:25, Amir Vaxman a écrit :
> Oh, right. What's the difference? That's the cmake I got from
> www.cmake.org, as recommended in CGAL installation, and I have previously
> used it to make my 32-bit version.
I am quite sure the one you launched is not the cmake from cmake.org but one
from cygwin.org. The difference is probably the way they deal with
environment
variables, and system environment variables.
Laurent Rineau, PhD
- RE: [cgal-discuss] cmake does not identify boost, (continued)
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Yang Liu, 02/02/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/02/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/03/2010
- Re: [cgal-discuss] cmake does not identify boost, Laurent Rineau (GeometryFactory), 02/03/2010
- RE: [cgal-discuss] cmake does not identify boost, Amir Vaxman, 02/10/2010
- Re: [cgal-discuss] cmake does not identify boost, Yang Liu, 02/10/2010
- [cgal-discuss] Pb with mesh_3D_image example, Sylvain Gouttebroze, 02/10/2010
