- To:
- Subject: Re: [cgal-discuss] Re: Neighbours list in 3D meshing
- Date: Tue, 04 May 2010 09:18:14 +0200
Ianic wrote:
I am still in the process of getting the neighbors list for all cells and
facets of a 3D mesh. Here is the code that I've written (I simply added it
to an example with a liver image):
typedef Tr::Cell_handle Cell_handle;
typedef C3t3::Cell_iterator Cell_iterator;
typedef Tr::Facet Facet;
typedef C3t3::Facet_iterator Facet_iterator;
typedef Tr::Facet_circulator Facet_circulator;
typedef Tr::Edge Edge;
typedef Tr::Vertex_handle Vertex_handle;
// A mesh connectivity file
std::ofstream neigh_file;
neigh_file.open("liver.neigh");
// 1.0 Cell connectivity
// Enumerating cells
std::map<Cell_handle, int> C;
int icell = 1;
for( Cell_iterator cit = c3t3.cells_begin() ;
cit != c3t3.cells_end() ;
++cit )
C[cit] = icell++;
// Writing cell connectivity data
neigh_file << "Cell neighbours" << std::endl
<< c3t3.number_of_cells() << std::endl;
++cit ) {
const Cell_handle& c = cit;
for ( int i=0 ; i<4 ; ++i ) {
const Cell_handle& neighbor = c->neighbor(i);
if ( c3t3.is_in_complex(neighbor) )
neigh_file << C[neighbor] << " ";
else
neigh_file << -1 << " ";
neigh_file << std::endl;
// 2.0 Facet connectivity
// Enumerating facets
std::map<Facet, int> F;
int ifacet = 1;
for( Facet_iterator fit = c3t3.facets_begin() ;
fit != c3t3.facets_end() ;
++fit )
F[*fit] = ifacet++;
// Writing facet connectivity data
neigh_file << "Facet neighbours" << std::endl
<< c3t3.number_of_facets() << std::endl;
std::vector<int> vert;
vert.resize(3);
std::vector<Edge> edge;
edge.resize(3);
for( Facet_iterator fit = c3t3.facets_begin();
fit != c3t3.facets_end();
++fit ) {
const Cell_handle& cell = fit->first;
int indexInCell = fit->second;
vert[0] = (indexInCell+1)%4;
vert[1] = (indexInCell+2)%4;
vert[2] = (indexInCell+3)%4;
edge[0] = Edge(cell, vert[1], vert[2]);
edge[1] = Edge(cell, vert[2], vert[0]);
edge[2] = Edge(cell, vert[0], vert[1]);
for (unsigned int i = 0; i < edge.size(); ++i) {
Facet_circulator fc = c3t3.triangulation().incident_facets(edge[i],
*fit);
Facet_circulator done(fc);
do {
if ( c3t3.is_in_complex(*fc) )
neigh_file << F[*fc] << " ";
} while (++fc != done);
neigh_file << "End" << std::endl;
neigh_file.close();
The cell neighbors list seems to be correct, though I am still wondering
what the neighbor(i) holds for a boundary cell, a NULL pointer?
Hi,
No. It is a Cell_handle pointing to:
+ an infinite cell, i.e. a cell which is incident to the infinite vertex (you could have a look in 3D Triangulation package documentation, and also here: http://www.cgal.org/Manual/last/doc_html/cgal_manual/TriangulationDS_3/Chapter_main.html).
+ a finite cell which is not part of the domain discretization
The facet code doesn't work. The idea essentially is that I take all 3 edges
of each facet, circulate over their incident facets that belong to a c3t3
complex (should be 2) and for each edge I write out the facet number which
is not the current one (this check is omitted in this code just now).
However, when I run this code, I get lots of zeros from this line:
Why does it happen? Can it be because I assign IDs to facets using typedef
C3t3::Facet_iterator, while when I go over the edge facets, I use typedef
Tr::Facet_circulator?
I didn't analyze deeply your code, but maybe this could help you.
In CGAL 3D Triangulation, Facet type is std::pair<Cell_handle,int>. Thus, each facet of the triangulation can be seen from two side (the side of each cell containing the facet). You could have a look at the method mirror_facet(Facet) of the triangulation API.
In your code, it seems that you don't take this into account. For example, you could fill your map with the facet seen from the cell which has the smallest Cell_handle, and do the same when you retrieve the data in your loop.
Best,
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/03/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/04/2010
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/04/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/06/2010
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/06/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/07/2010
