- To:
- Subject: [cgal-discuss] Re: Neighbours list in 3D meshing
- Date: Tue, 4 May 2010 01:04:54 -0700 (PDT)
> No. It is a Cell_handle pointing to:
> + an infinite cell, i.e. a cell which is incident to the infinite
> vertex (you could have a look in 3D Triangulation package documentation,
> and also here:
> http://www.cgal.org/Manual/last/doc_html/cgal_manual/TriangulationDS_3/Chapter_main.html).
> + a finite cell which is not part of the domain discretization
So, I assume that c3t3.is_in_complex(neighbor) will issue false for both of
these cases, is that right?
As for the facets, your suggestion is spot-on! When a circulator went over
facets it sometimes looked at them from a different cell, so they were not
present in my map. In this case I now take its mirror facet as a key for my
std::map and obtain the correct facet number. Thank you for your help,
Stephane.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Neighbours-list-in-3D-meshing-tp2075323p2125144.html
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/03/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/04/2010
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/04/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/06/2010
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/06/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/07/2010
