- To:
- Subject: Re: [cgal-discuss] Re: Neighbours list in 3D meshing
- Date: Thu, 06 May 2010 10:20:42 +0200
Ianic wrote:
Hi again!
Now that I have my mesh connectivity output, I tried to mesh a CT voxelized
image of a sandstone porous sample. It has only one subdomain - the pores.
So, theoretically, I expect the resulting surface to be manifold and all
facets to have 3 neighbors. When I looked at the output, I saw that some
facets had more than 3 neighbors, and looking at the resulting mesh itself,
I saw that there are some regions where 4 facets meet at one edge. I wonder
whether there is any way to guarantee the manifoldness of the boundary
surface? Or should I then try to construct the surface mesh and feed it to
the 3d mesher afterward?
Yan
Hi,
There is currently no way to guarantee the manifoldness of the output surface in CGAL 3D Mesh Generation package. Decreasing the approximation error might help to get the result you need.
As you say, you can try to use CGAL Surface Mesh generation algorithm (which has such a feature) to get a manifold surface. Then, you can insert the vertices of this surface mesh in a c3t3 and refine it with the 3D mesher (note that oracles with the same behaviour should be used).
Stéphane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/03/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/04/2010
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/04/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/06/2010
- [cgal-discuss] Re: Neighbours list in 3D meshing, Ianic, 05/06/2010
- Re: [cgal-discuss] Re: Neighbours list in 3D meshing, Stephane Tayeb, 05/07/2010
