- To: "" <>
- Subject: RE: [cgal-discuss] shortest line between two lines in 3d
- Date: Fri, 11 Jun 2010 10:27:41 -0500
- Accept-language: en-US
- Acceptlanguage: en-US
I don't know much about cgal for 3D but we can have a solution for your
question.
Let 2 lines be d1 and d2.
1. find the plane (p) that contains the d1 and perpendicular to d2
2. the intersection of d2 with p is p2.
3. find the intersection (p1)of the line passing p1 and perpendicular to d1.
It can be proved that p1p2 is the required line (segment).
Best,
Khuong
________________________________________
Sent: Friday, June 11, 2010 10:13 AM
To:
Subject: [cgal-discuss] shortest line between two lines in 3d
simple problem: i have two lines/rays in 3d and want to get the shortest line
that connects both (or similarly: the 3d point that has the shortest
distance to both lines).
i can only find the intersect method but this fits just for a special case.
Anybody knows if cgal can help here?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/shortest-line-between-two-lines-in-3d-tp2251943p2251943.html
- [cgal-discuss] shortest line between two lines in 3d, clemen, 06/11/2010
- RE: [cgal-discuss] shortest line between two lines in 3d, Vu, Khuong, 06/11/2010
- [cgal-discuss] RE: shortest line between two lines in 3d, clemen, 06/11/2010
- RE: [cgal-discuss] RE: shortest line between two lines in 3d, Vu, Khuong, 06/11/2010
- AW: [cgal-discuss] shortest line between two lines in 3d, Gärtner Bernd, 06/12/2010
- Re: AW: [cgal-discuss] shortest line between two lines in 3d, clemen, 06/14/2010
- RE: AW: [cgal-discuss] shortest line between two lines in 3d, Vu, Khuong, 06/14/2010
- [cgal-discuss] Finding points inside a rectangular region on space., Ricardo Bueno, 06/14/2010
- Re: [cgal-discuss] Finding points inside a rectangular region on space., Daniel Duque, 06/14/2010
- Re: [cgal-discuss] Finding points inside a rectangular region on space., Andreas Fabri, 06/14/2010
