- To: "" <>
- Subject: RE: AW: [cgal-discuss] shortest line between two lines in 3d
- Date: Mon, 14 Jun 2010 12:02:05 -0500
- Accept-language: en-US
- Acceptlanguage: en-US
That's nice :).
Khuong
________________________________________
Sent: Monday, June 14, 2010 8:23 AM
To:
Subject: Re: AW: [cgal-discuss] shortest line between two lines in 3d
Ok, thanks again. it turned out that khuong's way is pretty straightforward
to implement in cgal:
// get plane p1 that contains l1 and is parallel to l2
Plane_3 p1( l1, l1.point(0) + l2.to_vector() );
// get plane p2 that contains l1 and is perpendicular to p1
Plane_3 p2( l1, l1.point(0) + p1.orthogonal_vector() );
// get intersection i1 between p2 and l2
Point_3 i1;
CGAL::Object result = CGAL::intersection( p2, l2 );
if( !assign( i1, result ) ) {
Line_3 il;
if( assign( il, result ) )
std::cout << "intersection between plane and line is a line
--> l1 and l2
are parallel!" << std::endl;
return -1.0;
// get intersection i2 on l1
Point_3 i2 = l1.projection( i1 );
// final point is (i1+i2)/2
Point_3 f((i1.x() + i2.x()) / 2.0, (i1.y() + i2.y()) / 2.0, (i1.z() +
i2.z()) / 2.0);
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/shortest-line-between-two-lines-in-3d-tp2251943p2254338.html
- [cgal-discuss] shortest line between two lines in 3d, clemen, 06/11/2010
- RE: [cgal-discuss] shortest line between two lines in 3d, Vu, Khuong, 06/11/2010
- [cgal-discuss] RE: shortest line between two lines in 3d, clemen, 06/11/2010
- RE: [cgal-discuss] RE: shortest line between two lines in 3d, Vu, Khuong, 06/11/2010
- AW: [cgal-discuss] shortest line between two lines in 3d, Gärtner Bernd, 06/12/2010
- Re: AW: [cgal-discuss] shortest line between two lines in 3d, clemen, 06/14/2010
- RE: AW: [cgal-discuss] shortest line between two lines in 3d, Vu, Khuong, 06/14/2010
- [cgal-discuss] Finding points inside a rectangular region on space., Ricardo Bueno, 06/14/2010
- Re: [cgal-discuss] Finding points inside a rectangular region on space., Daniel Duque, 06/14/2010
- Re: [cgal-discuss] Finding points inside a rectangular region on space., Andreas Fabri, 06/14/2010
