- To: <>
- Subject: AW: [cgal-discuss] shortest line between two lines in 3d
- Date: Sat, 12 Jun 2010 13:26:08 +0200
You could also write the rays/lines as linear (in)equality systems in
different variable vectors x,y, and then use the quadratic programming solver
to minimize the squared norm of x-y, see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/QP_solver/Chapter_main.html
Best,
Bernd.
________________________________
Von: clemen
[mailto:]
Gesendet: Fr 6/11/2010 5:13
An:
Betreff: [cgal-discuss] shortest line between two lines in 3d
simple problem: i have two lines/rays in 3d and want to get the shortest line
that connects both (or similarly: the 3d point that has the shortest
distance to both lines).
i can only find the intersect method but this fits just for a special case.
Anybody knows if cgal can help here?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/shortest-line-between-two-lines-in-3d-tp2251943p2251943.html
- [cgal-discuss] shortest line between two lines in 3d, clemen, 06/11/2010
- RE: [cgal-discuss] shortest line between two lines in 3d, Vu, Khuong, 06/11/2010
- [cgal-discuss] RE: shortest line between two lines in 3d, clemen, 06/11/2010
- RE: [cgal-discuss] RE: shortest line between two lines in 3d, Vu, Khuong, 06/11/2010
- AW: [cgal-discuss] shortest line between two lines in 3d, Gärtner Bernd, 06/12/2010
- Re: AW: [cgal-discuss] shortest line between two lines in 3d, clemen, 06/14/2010
- RE: AW: [cgal-discuss] shortest line between two lines in 3d, Vu, Khuong, 06/14/2010
- [cgal-discuss] Finding points inside a rectangular region on space., Ricardo Bueno, 06/14/2010
- Re: [cgal-discuss] Finding points inside a rectangular region on space., Daniel Duque, 06/14/2010
- Re: [cgal-discuss] Finding points inside a rectangular region on space., Andreas Fabri, 06/14/2010
