cgal-discuss - RE: [cgal-discuss] RE: shortest line between two lines in 3d
  • To: "" <>
  • Subject: RE: [cgal-discuss] RE: shortest line between two lines in 3d
  • Date: Fri, 11 Jun 2010 12:37:44 -0500
  • Accept-language: en-US
  • Acceptlanguage: en-US
Well, if not then you can solve the problem yourself. You may want to see the
formulas in
http://www.math.dartmouth.edu/archive/m8w07/public_html/Lecture17.pdf
Good luck
Khuong
________________________________________
Sent: Friday, June 11, 2010 11:02 AM
To:
Subject: [cgal-discuss] RE: shortest line between two lines in 3d
Thanks.
So the problem may got simpler but still exists: Is there a cgal way to
"Find the plan (p') containing d1 and parallel to d2." ?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/shortest-line-between-two-lines-in-3d-tp2251943p2252006.html
