- To:
- Subject: [cgal-discuss] Error building examples
- Date: Wed, 11 Aug 2010 17:38:48 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=LtDDF0nWn1D9J8sx6yIhl5vZCi23heQjVjEg50qZP75AeKaV1+zM31wBkHHFl9NqCG 8XzEEs0UaxuQhCpPC13OOoySrXvycJcGyD13a4b/VRVd6sfgfMXxRg34YhgGWyr38jux cmtUpAz1UIq6NSnXaIE+kr1U70KOGuEAMJs1w=
Hi all,
I'm having problems running the examples in CGAL/examples.
First I installed CGAL with
cmake .
makeĀ
sudo make install
Everything goes fine (except CGAL_Qt3 and CGAL_Qt4, but I think it doesn't matter).
Then, to run an example, I try for example the AABB_tree directory.
There I do
cmake .
andĀ
make
But in this one I receive an error mesage:
Scanning dependencies of target AABB_custom_example
[ 12%] Building CXX object CMakeFiles/AABB_custom_example.dir/AABB_custom_example.o
Linking CXX executable AABB_custom_example
/usr/local/lib/libCGAL.so: undefined reference to `boost::detail::set_tss_data(void const*, boost::shared_ptr<boost::detail::tss_cleanup_function>, void*, bool)'
collect2: ld returned 1 exit status
make[2]: *** [AABB_custom_example] Error 1
make[1]: *** [CMakeFiles/AABB_custom_example.dir/all] Error 2
make: *** [all] Error 2
It seems that the problem is with boost library, but it didn't showed errors when I was building/installing CGAL.
Does anyone have a clue about this error?
Thanks!
Guilherme Kunigami
Guilherme Kunigami
- [cgal-discuss] Error building examples, Guilherme Kunigami, 08/11/2010
- [cgal-discuss] Re: Error building examples, Guilherme Kunigami, 08/12/2010
- Re: [cgal-discuss] Error building examples, Andres E. Prato, 08/18/2010
- Re: [cgal-discuss] Error building examples, Joachim Reichel, 08/18/2010
- [cgal-discuss] Error building examples Ubuntu Lucid Lynx, Andres E. Prato, 08/19/2010
- Re: [cgal-discuss] Error building examples Ubuntu Lucid Lynx, Joachim Reichel, 08/19/2010
