- To:
- Subject: [cgal-discuss] Re: Error building examples
- Date: Thu, 12 Aug 2010 14:36:40 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=qUswvHUKYOWA1k29duJvZMw+uzEZdpjyJ4OsXUpRBpePjpqV3lhGJ+PSoEzGurrwXD a8m8hWPOXvte+weP+FPcLAph3WVJIwWsb5bzUcJqJdyu8TbjIOHs6CiRVmhndkLrO68W vFDXNyyGLWAiSw0uVH9f+g3KApqZN9YwbIOxA=
I think I discovered the problem. To inform cmake the right path, just do
cmake -DBOOST_ROOT=/usr/local/ .
Regards,
Guilherme Kunigami
On Thu, Aug 12, 2010 at 8:58 AM, Guilherme Kunigami <> wrote:
Hi again,
Apparently, the error is due to the incorrect linking to the boost library, as can be seen below (appendix). I built boost 1.43.0 although it seems cmake only finds 1.34.1. The new version of boost seems to be in /usr/local/include and /usr/local/lib. I tried creating the environment variable (according to [1]):BOOST_ROOT=/usr/local/
But it didn't work. Then I tried to be more specific:BOOST_INCLUDEDIR=/usr/local/includeBOOST_LIBRARYDIR=/usr/local/libIt didn't work either. Do I have to set the variables through cmake too?Thanks,
Appendix:
-- CGAL_MAJOR_VERSION=3-- CGAL_MINOR_VERSION=6-- CGAL_BUILD_VERSION=-- CGAL_SONAME_VERSION=5-- CGAL_SOVERSION =5.0.0-- CGAL_REFERENCE_CACHE_DIR=-- Building shared libraries-- Targetting Unix Makefiles-- Using /usr/bin/c++ compiler.-- USING CMake version: 2.4.7-- System: Linux-- USING GCC_VERSION = '4.2.4 (Ubuntu 4.2.4-1ubuntu4)'-- Using gcc version 4 or later. Adding -frounding-math-- Using gcc version 4.2. Adding -fno-strict-aliasing-- Build type: Release-- USING CXXFLAGS = ' -frounding-math -fno-strict-aliasing -O3 -DNDEBUG'-- USING LDFLAGS = ' '-- GMPXX include: /usr/include-- GMPXX libraries: /usr/lib/libgmpxx.so-- GMP include: /usr/include-- GMP libraries: /usr/lib/libgmp.so-- GMP definitions:-- USING GMP_VERSION = '4.2.2'-- MPFR include: /usr/include-- MPFR libraries: /usr/lib/libmpfr.so-- MPFR definitions:-- USING MPFR_VERSION = '2.3.1'-- Boost include: /usr/include-- Boost libraries: optimized;/usr/lib/libboost_thread-gcc42-mt-1_34_1.so;debug;/usr/lib/libboost_thread-gcc42-mt-d-1_34_1.so-- Boost definitions:-- USING BOOST_VERSION = '1.34.1'-- CMAKE_INSTALL_PREFIX=/usr/local-- OpenGL include: /usr/include-- OpenGL libraries: /usr/lib/libGLU.so;/usr/lib/libGL.so;/usr/lib/libX11.so-- USING ZLIB_VERSION = '1.2.3'-- ZLib include: /usr/include-- ZLib libraries: /usr/lib/libz.so-- CGAL_Qt3 needs Qt3, cannot be configured.-- CGAL_Qt4 needs Qt4, cannot be configured.-- Configuring done-- Generating done--
On Wed, Aug 11, 2010 at 5:38 PM, Guilherme Kunigami <> wrote:Hi all,I'm having problems running the examples in CGAL/examples.First I installed CGAL withcmake .makesudo make installEverything goes fine (except CGAL_Qt3 and CGAL_Qt4, but I think it doesn't matter).Then, to run an example, I try for example the AABB_tree directory.There I docmake .andmakeBut in this one I receive an error mesage:Scanning dependencies of target AABB_custom_example[ 12%] Building CXX object CMakeFiles/AABB_custom_example.dir/AABB_custom_example.oLinking CXX executable AABB_custom_example/usr/local/lib/libCGAL.so: undefined reference to `boost::detail::set_tss_data(void const*, boost::shared_ptr<boost::detail::tss_cleanup_function>, void*, bool)'collect2: ld returned 1 exit statusmake[2]: *** [AABB_custom_example] Error 1make[1]: *** [CMakeFiles/AABB_custom_example.dir/all] Error 2make: *** [all] Error 2It seems that the problem is with boost library, but it didn't showed errors when I was building/installing CGAL.Does anyone have a clue about this error?Thanks!--
Guilherme Kunigami
Guilherme Kunigami
Guilherme Kunigami
- [cgal-discuss] Error building examples, Guilherme Kunigami, 08/11/2010
- [cgal-discuss] Re: Error building examples, Guilherme Kunigami, 08/12/2010
- Re: [cgal-discuss] Error building examples, Andres E. Prato, 08/18/2010
- Re: [cgal-discuss] Error building examples, Joachim Reichel, 08/18/2010
- [cgal-discuss] Error building examples Ubuntu Lucid Lynx, Andres E. Prato, 08/19/2010
- Re: [cgal-discuss] Error building examples Ubuntu Lucid Lynx, Joachim Reichel, 08/19/2010
