cgal-discuss - [cgal-discuss] Error building examples Ubuntu Lucid Lynx
  • To:
  • Subject: [cgal-discuss] Error building examples Ubuntu Lucid Lynx
  • Date: Wed, 18 Aug 2010 21:39:18 -0300
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.ar; h=DKIM-Signature:Received:X-Yahoo-SMTP:X-YMail-OSG:X-Yahoo-Newman-Property:Message-ID:Date:From:User-Agent:MIME-Version:To:Subject:References:In-Reply-To:Content-Type; b=g9HatT12S9A0tZOys2mNRZJSA+90Ao50oP2N9ET0RVJkwvWTGJPlt5m/CXWyWGVHLNT2Db5lDyslX1dVTx/sxVz+gYWfmilczqJEzUuEppZEdt62w6GyreyJNTlGE7iiGjW1e/rez5VbKMss20JJFcE0IdDT4QoaqfhMEyXSyyM= ;
Reichel:
Sorry for not starting a new tread. I Attached my system log... there is some things about memory, I got 1 GB of RAM, a T5500 intel core 2 duo, and I got 3 GB of free space on my home directory....
After the error appeared, I got some configuration problems on my Ubuntu-Gnome desktop, some Icons disappeared, and I had to restart everything....
Thanks..
Andrés
Andres E. Prato wrote:
I have problemas with CGAL - examples.
I am new and starting with CGAL, and I cant compile the examples, I did:
please don't reply to other thread if you have unrelated problems, start a new
thread instead.
cmake .
When I do make:
After a wile....
Linking CXX executable mesh_global
[ 38%] Built target mesh_global
Scanning dependencies of target mesh_with_seeds
[ 39%] Building CXX object
Mesh_2/CMakeFiles/mesh_with_seeds.dir/mesh_with_seeds.o
Linking CXX executable mesh_with_seeds
[ 39%] Built target mesh_with_seeds
Scanning dependencies of target mesh_3D_image
Mesh_3/CMakeFiles/mesh_3D_image.dir/mesh_3D_image.o
c++: Internal error: Terminado (killed) (program cc1plus)
Please submit a full bug report.
See<file:///usr/share/doc/gcc-4.4/README.Bugs> for instructions.
make[2]: *** [Mesh_3/CMakeFiles/mesh_3D_image.dir/mesh_3D_image.o] Error 1
make[1]: *** [Mesh_3/CMakeFiles/mesh_3D_image.dir/all] Error 2
make: *** [all] Error 2
Your compiler process got killed. Maybe you don't have enough free memory? Can
you check whether /var/log/syslog contains any messages about killed
processes?
Joachim
00:02:cf:c5:24:7a [GTK=TKIP]
Aug 17 23:02:55 andres-laptop NetworkManager: <info> (wlan0): supplicant
connection state: completed -> group handshake
connection state: group handshake -> completed
Aug 17 23:08:54 andres-laptop NetworkManager: <info> (wlan0): supplicant
connection state: completed -> 4-way handshake
Aug 17 23:08:56 andres-laptop NetworkManager: <info> (wlan0): supplicant
connection state: 4-way handshake -> group handshake
Aug 17 23:08:56 andres-laptop wpa_supplicant[1043]: WPA: Key negotiation
completed with 00:02:cf:c5:24:7a [PTK=TKIP GTK=TKIP]
Aug 17 23:09:51 andres-laptop wpa_supplicant[1043]: WPA: Group rekeying
completed with 00:02:cf:c5:24:7a [GTK=TKIP]
Aug 17 23:09:51 andres-laptop NetworkManager: <info> (wlan0): supplicant
Aug 17 23:12:54 andres-laptop wpa_supplicant[1043]: WPA: Group rekeying
Aug 17 23:12:54 andres-laptop NetworkManager: <info> (wlan0): supplicant
Aug 17 23:17:02 andres-laptop CRON[7647]: (root) CMD ( cd / && run-parts
--report /etc/cron.hourly)
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548612] __ratelimit: 6 callbacks
suppressed
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548620] compiz invoked
oom-killer: gfp_mask=0x201da, order=0, oom_adj=0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548627] compiz cpuset=/
mems_allowed=0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548634] Pid: 1471, comm: compiz
Not tainted 2.6.32-24-generic #39-Ubuntu
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548638] Call Trace:
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548652] [<c01cd1f4>]
oom_kill_process+0xa4/0x2b0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548660] [<c01cd869>] ?
select_bad_process+0xa9/0xe0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548667] [<c01cd8f1>]
__out_of_memory+0x51/0xa0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548674] [<c01cd998>]
out_of_memory+0x58/0xb0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548681] [<c01d01a7>]
__alloc_pages_slowpath+0x407/0x4a0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548689] [<c01d037a>]
__alloc_pages_nodemask+0x13a/0x170
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548698] [<c01d29ba>]
__do_page_cache_readahead+0xea/0x200
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548705] [<c01d2af6>]
ra_submit+0x26/0x30
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548712] [<c01ccaec>]
filemap_fault+0x3dc/0x410
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548719] [<c01e5040>]
__do_fault+0x40/0x490
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548727] [<c01e6c49>]
handle_mm_fault+0x139/0x390
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548736] [<c058f1bd>]
do_page_fault+0x10d/0x3a0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548744] [<c058d400>] ?
do_device_not_available+0x0/0x60
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548751] [<c058f0b0>] ?
do_page_fault+0x0/0x3a0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548758] [<c058d0b3>]
error_code+0x73/0x80
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548762] Mem-Info:
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548766] DMA per-cpu:
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548771] CPU 0: hi: 0,
btch: 1 usd: 0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548775] CPU 1: hi: 0,
btch: 1 usd: 0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548779] Normal per-cpu:
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548783] CPU 0: hi: 186,
btch: 31 usd: 95
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548788] CPU 1: hi: 186,
btch: 31 usd: 173
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548791] HighMem per-cpu:
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548795] CPU 0: hi: 42,
btch: 7 usd: 35
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548800] CPU 1: hi: 42,
btch: 7 usd: 13
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548809] active_anon:212052
inactive_anon:25934 isolated_anon:0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548811] active_file:375
inactive_file:418 isolated_file:0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548814] unevictable:4 dirty:0
writeback:0 unstable:0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548816] free:2972
slab_reclaimable:1527 slab_unreclaimable:2902
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548818] mapped:1427 shmem:16569
pagetables:1666 bounce:0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548830] DMA free:4024kB min:64kB
low:80kB high:96kB active_anon:3468kB inactive_anon:1036kB active_file:0kB
inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB
present:15852kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB
slab_reclaimable:0kB slab_unreclaimable:8kB kernel_stack:0kB pagetables:8kB
unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:256
all_unreclaimable? yes
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548840] lowmem_reserve[]: 0 865
991 991
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548858] Normal free:7696kB
min:3728kB low:4660kB high:5592kB active_anon:783440kB inactive_anon:41344kB
active_file:972kB inactive_file:1108kB unevictable:16kB isolated(anon):0kB
isolated(file):0kB present:885944kB mlocked:16kB dirty:0kB writeback:0kB
mapped:5148kB shmem:57556kB slab_reclaimable:6108kB
slab_unreclaimable:11600kB kernel_stack:2208kB pagetables:5312kB unstable:0kB
bounce:0kB writeback_tmp:0kB pages_scanned:2528 all_unreclaimable? no
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548869] lowmem_reserve[]: 0 0
1006 1006
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548886] HighMem free:168kB
min:128kB low:260kB high:396kB active_anon:61300kB inactive_anon:61356kB
active_file:528kB inactive_file:564kB unevictable:0kB isolated(anon):0kB
isolated(file):0kB present:128860kB mlocked:0kB dirty:0kB writeback:0kB
mapped:560kB shmem:8720kB slab_reclaimable:0kB slab_unreclaimable:0kB
kernel_stack:0kB pagetables:1344kB unstable:0kB bounce:0kB writeback_tmp:0kB
pages_scanned:192 all_unreclaimable? no
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548896] lowmem_reserve[]: 0 0 0 0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548906] DMA: 0*4kB 1*8kB 1*16kB
1*32kB 0*64kB 1*128kB 1*256kB 1*512kB 1*1024kB 1*2048kB 0*4096kB = 4024kB
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548929] Normal: 1060*4kB 8*8kB
2*16kB 1*32kB 2*64kB 1*128kB 0*256kB 0*512kB 1*1024kB 1*2048kB 0*4096kB =
7696kB
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548952] HighMem: 12*4kB 1*8kB
1*16kB 1*32kB 1*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB =
168kB
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548975] 17395 total pagecache
pages
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548978] 0 pages in swap cache
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548982] Swap cache stats: add 0,
delete 0, find 0/0
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548986] Free swap = 0kB
Aug 17 23:19:01 andres-laptop kernel: [ 2440.548988] Total swap = 0kB
Aug 17 23:19:01 andres-laptop kernel: [ 2440.552840] 259795 pages RAM
Aug 17 23:19:01 andres-laptop kernel: [ 2440.552844] 32469 pages HighMem
Aug 17 23:19:01 andres-laptop kernel: [ 2440.552848] 5500 pages reserved
Aug 17 23:19:01 andres-laptop kernel: [ 2440.552851] 17485 pages shared
Aug 17 23:19:01 andres-laptop kernel: [ 2440.552854] 236599 pages non-shared
Aug 17 23:19:01 andres-laptop kernel: [ 2440.552860] Out of memory: kill
process 1688 (run-mozilla.sh) score 292228 or a child
Aug 17 23:19:01 andres-laptop kernel: [ 2440.552866] Killed process 1693
(thunderbird-bin)
Aug 17 23:32:59 andres-laptop wpa_supplicant[1043]: WPA: Group rekeying
Aug 17 23:32:58 andres-laptop kernel: [ 3279.100764] wlan0: disassociated
from 00:02:cf:c5:24:7a (Reason: 16)
Aug 17 23:32:59 andres-laptop wpa_supplicant[1043]: CTRL-EVENT-DISCONNECTED -
Disconnect event - remove keys
Aug 17 23:33:01 andres-laptop kernel: [ 3279.132498] wlan0: deauthenticating
from 00:02:cf:c5:24:7a by local choice (reason=3)
Aug 17 23:33:05 andres-laptop wpa_supplicant[1043]: WPA: Key negotiation
Aug 17 23:33:14 andres-laptop wpa_supplicant[1043]: CTRL-EVENT-CONNECTED -
Connection to 00:00:00:00:00:00 completed (reauth) [id=0 id_str=]
Aug 17 23:33:35 andres-laptop wpa_supplicant[1043]: WPA: Group rekeying
Aug 17 23:33:47 andres-laptop NetworkManager: <debug> [1282098818.777349]
periodic_update(): Roamed from BSSID 00:02:CF:C5:24:7A (gaby2009) to (none)
((none))
Aug 17 23:33:51 andres-laptop wpa_supplicant[1043]: Trying to associate with
00:02:cf:c5:24:7a (SSID='gaby2009' freq=2412 MHz)
Aug 17 23:34:02 andres-laptop kernel: [ 3342.866945] wlan0: direct probe to
AP 00:02:cf:c5:24:7a (try 1)
Aug 17 23:34:04 andres-laptop kernel: [ 3342.869388] wlan0: direct probe
responded
Aug 17 23:34:05 andres-laptop kernel: [ 3342.869394] wlan0: authenticate with
Aug 17 23:34:05 andres-laptop kernel: [ 3342.871770] wlan0: authenticated
Aug 17 23:34:05 andres-laptop kernel: [ 3342.871799] wlan0: associate with AP
Aug 17 23:34:05 andres-laptop kernel: [ 3342.874995] wlan0: RX AssocResp from
00:02:cf:c5:24:7a (capab=0x431 status=0 aid=2)
Aug 17 23:34:05 andres-laptop kernel: [ 3342.875000] wlan0: associated
Aug 17 23:34:05 andres-laptop kernel: [ 3347.879510] wlan0: disassociated
Aug 17 23:34:05 andres-laptop kernel: [ 3347.904446] wlan0: deauthenticating
Aug 17 23:34:16 andres-laptop wpa_supplicant[1043]: Associated with
00:00:00:00:00:00
Aug 17 23:34:17 andres-laptop wpa_supplicant[1043]: CTRL-EVENT-DISCONNECTED -
Aug 17 23:34:28 andres-laptop wpa_supplicant[1043]: WPA: No SSID info found
(msg 1 of 4).
Aug 17 23:34:40 andres-laptop wpa_supplicant[1043]: Trying to associate with
Aug 17 23:34:40 andres-laptop kernel: [ 3380.153761] wlan0: direct probe to
Aug 17 23:34:41 andres-laptop kernel: [ 3380.156124] wlan0: direct probe
responded
Aug 17 23:34:41 andres-laptop kernel: [ 3380.156129] wlan0: authenticate with
Aug 17 23:34:41 andres-laptop kernel: [ 3380.157627] wlan0: authenticated
Aug 17 23:34:41 andres-laptop kernel: [ 3380.157659] wlan0: associate with AP
Aug 17 23:34:41 andres-laptop kernel: [ 3380.159598] wlan0: RX AssocResp from
Aug 17 23:34:41 andres-laptop kernel: [ 3380.159603] wlan0: associated
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816276] NetworkManager invoked
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816286] NetworkManager cpuset=/
mems_allowed=0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816293] Pid: 883, comm:
NetworkManager Not tainted 2.6.32-24-generic #39-Ubuntu
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816298] Call Trace:
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816311] [<c01cd1f4>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816320] [<c01cd869>] ?
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816327] [<c01cd8f1>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816333] [<c01cd998>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816340] [<c01d01a7>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816348] [<c01d037a>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816357] [<c01d29ba>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816364] [<c01d2af6>]
ra_submit+0x26/0x30
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816370] [<c01ccaec>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816378] [<c01e5040>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816385] [<c01e6c49>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816395] [<c058f1bd>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816402] [<c058f0b0>] ?
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816409] [<c058d0b3>]
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816414] Mem-Info:
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816418] DMA per-cpu:
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816422] CPU 0: hi: 0,
btch: 1 usd: 0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816427] CPU 1: hi: 0,
btch: 1 usd: 0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816431] Normal per-cpu:
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816435] CPU 0: hi: 186,
btch: 31 usd: 177
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816440] CPU 1: hi: 186,
btch: 31 usd: 109
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816443] HighMem per-cpu:
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816448] CPU 0: hi: 42,
btch: 7 usd: 30
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816452] CPU 1: hi: 42,
btch: 7 usd: 39
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816462] active_anon:119405
inactive_anon:118867 isolated_anon:0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816464] active_file:348
inactive_file:300 isolated_file:0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816466] unevictable:4 dirty:0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816468] free:2965
slab_reclaimable:1509 slab_unreclaimable:2889
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816470] mapped:1401 shmem:16011
pagetables:1597 bounce:0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816483] DMA free:4024kB min:64kB
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816493] lowmem_reserve[]: 0 865
991 991
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816510] Normal free:7724kB
min:3728kB low:4660kB high:5592kB active_anon:412496kB inactive_anon:412764kB
active_file:1064kB inactive_file:1060kB unevictable:16kB isolated(anon):0kB
mapped:5112kB shmem:55372kB slab_reclaimable:6036kB
slab_unreclaimable:11548kB kernel_stack:2128kB pagetables:5032kB unstable:0kB
bounce:0kB writeback_tmp:0kB pages_scanned:3328 all_unreclaimable? yes
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816521] lowmem_reserve[]: 0 0
1006 1006
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816538] HighMem free:112kB
min:128kB low:260kB high:396kB active_anon:61656kB inactive_anon:61668kB
active_file:328kB inactive_file:140kB unevictable:0kB isolated(anon):0kB
mapped:492kB shmem:8672kB slab_reclaimable:0kB slab_unreclaimable:0kB
kernel_stack:0kB pagetables:1348kB unstable:0kB bounce:0kB writeback_tmp:0kB
pages_scanned:688 all_unreclaimable? yes
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816548] lowmem_reserve[]: 0 0 0 0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816557] DMA: 0*4kB 1*8kB 1*16kB
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816581] Normal: 999*4kB 30*8kB
0*16kB 3*32kB 1*64kB 0*128kB 1*256kB 0*512kB 1*1024kB 1*2048kB 0*4096kB =
7724kB
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816603] HighMem: 0*4kB 0*8kB
112kB
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816626] 16671 total pagecache
pages
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816629] 0 pages in swap cache
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816633] Swap cache stats: add 0,
delete 0, find 0/0
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816637] Free swap = 0kB
Aug 17 23:34:41 andres-laptop kernel: [ 3381.816640] Total swap = 0kB
Aug 17 23:34:41 andres-laptop kernel: [ 3381.820459] 259795 pages RAM
Aug 17 23:34:41 andres-laptop kernel: [ 3381.820463] 32469 pages HighMem
Aug 17 23:34:41 andres-laptop kernel: [ 3381.820466] 5500 pages reserved
Aug 17 23:34:41 andres-laptop kernel: [ 3381.820469] 15446 pages shared
Aug 17 23:34:41 andres-laptop kernel: [ 3381.820472] 239103 pages non-shared
Aug 17 23:34:41 andres-laptop kernel: [ 3381.820478] Out of memory: kill
process 7668 (cc1plus) score 215721 or a child
Aug 17 23:34:41 andres-laptop kernel: [ 3381.820484] Killed process 7668
(cc1plus)
Aug 17 23:34:41 andres-laptop wpa_supplicant[1043]: Associated with
00:02:cf:c5:24:7a
Aug 17 23:34:41 andres-laptop wpa_supplicant[1043]: WPA: Key negotiation
Aug 17 23:34:41 andres-laptop wpa_supplicant[1043]: CTRL-EVENT-CONNECTED -
Connection to 00:02:cf:c5:24:7a completed (reauth) [id=0 id_str=]
Aug 17 23:34:41 andres-laptop NetworkManager: <debug> [1282098881.874039]
periodic_update(): Roamed from BSSID (none) ((none)) to 00:02:CF:C5:24:7A
(gaby2009)
Aug 17 23:34:42 andres-laptop NetworkManager: <info> (wlan0): supplicant
connection state: completed -> disconnected
connection state: disconnected -> group handshake
connection state: completed -> associating
connection state: associating -> associated
connection state: associated -> disconnected
connection state: disconnected -> scanning
connection state: scanning -> associating
connection state: associating -> 4-way handshake
connection state: 4-way handshake -> associated
connection state: associated -> 4-way handshake
Aug 17 23:37:54 andres-laptop wpa_supplicant[1043]: WPA: Group rekeying
Aug 17 23:37:54 andres-laptop NetworkManager: <info> (wlan0): supplicant
Aug 17 23:39:47 andres-laptop wpa_supplicant[1043]: WPA: Group rekeying
Aug 17 23:39:47 andres-laptop NetworkManager: <info> (wlan0): supplicant
Aug 17 23:57:25 andres-laptop wpa_supplicant[1043]: WPA: Group rekeying
Aug 17 23:57:25 andres-laptop NetworkManager: <info> (wlan0): supplicant
