- To:
- Subject: Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?
- Date: Fri, 22 Oct 2010 22:24:33 +0200
Hi,
> The problem is due to floating point rounding.
> Depending of the optimization done by the compiler an expression
> was not evaluated the same way.
> For convenience, I made a fix which solve the "problem" on my machine
> (patch file attached).
Thank you, the fix solves the problem for me.
Will this fix be in future versions of CGAL? I'm not sure if you
consider it a 'real' problem since you put the quotation marks around
"problem". :-)
Best regards, | Institut für Theoretische Physik I
Sebastian Kapfer | Staudtstr. 7, FAU Erlangen-Nürnberg
| Building B3, room #02.585
| Phone: +49-9131-85-2-8452
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, (continued)
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Laurent Rineau (GeometryFactory), 10/20/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Laurent Rineau (GeometryFactory), 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/21/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/22/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/22/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastien Loriot (GeometryFactory), 10/25/2010
- Re: [cgal-discuss] Spatial Searching: How to cope with duplicate points?, Sebastian Kapfer, 10/26/2010
